Serious buyer looking for good used S-Trim
Old Apr 9, 2004 | 11:09 AM
  #16
97WS6SCharged's Avatar
Yes, the stock balancer works fine, just make sure you retorque the bolts down to spec.
Old Apr 10, 2004 | 12:19 AM
  #17
canbaufo's Avatar
Originally posted by magius231
I'm a little confused about your reasoning though...I admit I don't know that much about superchargers, but a good cam with LE heads by itself should be pulling 400RWHP, how are you only getting 50RWHP from 5.5psi? I would think it would be more like 20hp/lb, so +110rwhp or ~500rwhp like your looking for..?
Common logic would have one believe this, however you cannot always "stack" horsepower. That same "good cam" and heads isn't likely to be the optimal design for supercharging if it makes that much power N/A. Blower cams need to be milder to make use of the blower via a good cylinder fill....which will generally make less power N/A without the blower than an N/A cam. Most Powerdyne users with appropriately matched heads and cam only make 425-440 rwhp ....so I will likely even fall short of 450 if I stay with it to be honest with you. The lack of efficiency (compressor mapping) doesn't help the little PD much either....it is really best left on a stock motor or a mild motor with modest power goals.
LMW, I was unable to play the video due to my 21,600 bps connection .....waited for 1/2 hour and got nothing but a blank white screen....thanks for trying though. If anyone has a regular video that will play in Media Player that's what I'd like ...thanks.
Old Apr 10, 2004 | 01:16 AM
  #18
I wish mine sounded that good at idle. Guess if I was using my 15 lb pulleys it would, but that isn't happenning anytime soon.
Old Apr 10, 2004 | 01:21 AM
  #19
canbaufo's Avatar
Unhappy
Anyone have a media player video of a P600B or either S-Trim? I have searched and searched and cannot find anything!
Old Apr 10, 2004 | 01:27 AM
  #20
CJ's Avatar
CJ
I emailed you two clips, one of a P600B and one of a T-trim.
Old Apr 10, 2004 | 05:50 AM
  #21
magius231's Avatar
wow I'd be majorly upset if I spent money on heads/cam and a supercharger and still didn't make 450RWHP theres some people making that N/A...
Old Apr 11, 2004 | 01:21 PM
  #22
canbaufo's Avatar
....did you send it to someone else by accident? There is nothing in my inbox, thanks though. I'm still unable to find a video or soundclip of any blower whatsoever .....anyone???
Old Apr 11, 2004 | 01:31 PM
  #23
canbaufo's Avatar
Exactly. To add to that I've also been through the expense of a dyno tuning fiasco that set me back 3K ....now a rebuild that will set me back close to 7K which was probaby caused by the dyno tuning . That is why I can't accept the idea of settling for much less than 500 rwhp at this point.....if I've been through all of this nightmare stuff, by God I'm going to get something worthwile out of it.
My engine will have studded 2-bolt mains (ARP), a reconditioned forged crank from a 1-ton truck, Scat 4340 I-beams, Speed Pro Dished forged pistons, Federal Mogul coated bearings, a keyed hub, static CR of ~9.5:1 ......so I think 9-10 PSI intercooled or non intercooled will be handled well by this combo and still allow pump gas as long as I'm conservative on timing and keep it kinda rich. Do you all agree? I know the CR could be a little lower but it was designed for the Powerdyne ....I still think it would be ok though as long as I stay at 10 PSI or less.
Old Apr 11, 2004 | 03:11 PM
  #24
CJ's Avatar
CJ
Check again
I sent them again to: clynch3@citynet.net
Old Apr 11, 2004 | 07:51 PM
  #25
schpenxel's Avatar
I'm not sure "20hp/lb" is a valid constant...Maybe on a turbo, but not on a supercharger given how much horsepower it takes to drive it. Even at low boost levels it takes a bit of energy to turn the s/c that fast...You have to get past a certain amount of boost before it cancels out and makes more power than just not having it at all, which in my opinion is just a little under what he's running. Bumping it up a little higher will make huge gains, IMO.
Carson
Old Apr 11, 2004 | 11:11 PM
  #26
canbaufo's Avatar
Thumbs up
Check again
Thanks ....finally some videos I can view. It's kind of hard to tell from the video what the whine on yours really sounds like (as you said it's from behind as you're leaving) ...but from what I could hear it didn't sound so loud to me. Just curious ...what cam are you using, sounds a little big and nasty or in need of tuning one or the other. Either way your car and the T-Trim car both sound awesome
Old Apr 12, 2004 | 01:54 AM
  #27
CJ's Avatar
CJ
Im sure I have some other clips around here that are a little better, those are just the first two i came across. If i find some others ill let you know. The cam I was running was the ccxe 224/236.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
marineengineer
Feb 9, 2015 03:59 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
Fbodfather
25
Jun 21, 2002 04:12 PM
