S-Trim to T-trim questions
Old Feb 2, 2005 | 09:59 PM
LT1runner's Avatar
Question S-Trim to T-trim questions
Given an average blower condition, how much do you guys think it would cost to upgrade from a V-2 SQ S-trim to a T-Trim?
Out of all who have done this already, was it worth it afterwards? I'm currently doing 12psi with my SQ S-Trim(w/aftercooler), and thought about going up to the T-Trim to get more power. I don't really have a power goal(per se), just want to spin a T-Trim to the upper most safe rpm limit, while keeping the A/F ratio at or around 11.5.
With engine analizer I seem to come out at 535+\- rwhp. The motor is built for boost and I'm running the dreadded cc305 @114 lsa. Which brings up another delima, what cam should I go with. I'm trying to figure this out, so don't feel like commenting on that one because I don't have my new flow numbers due to my heads are currently being worked over and freashed up again. My CR will be around 9 to 1 or 9.1 to 1.
Just wondering what are the pros and cons to stepping up to a T-Trim. And from those that have done it, would you recomend someone else to do it.
Old Feb 2, 2005 | 11:02 PM
n2oblkz
Guest
Posts: n/a
Re: S-Trim to T-trim questions
I can't think of an cons to stepping up to the T-trim, you will only gain performance. As far as price, do a search here and see what some of the T-trims have been listed for in the parts for sale section, it will give you an idea of about how much they have been going for. I have seen some pretty good deals on them in the past.
As far as the cam, when you get your flow numbers, get in touch with an engine builder or a cam manufacturer to have a custom grind made. There was a thread a few days ago about custom cams and guys here on the board seem to be satisfied with SStrokerAce and the cams he sets them up with.
Old Feb 3, 2005 | 04:26 PM
ss#1230's Avatar
vortech has an exchange program.....usually $1000+ upgrade with the trade in.
the info is on the site........www.vortechsuperchargers.com
Old Feb 3, 2005 | 10:18 PM
EDS Z28's Avatar
One con is the T-trim will make way more noise. That is one of the reasons I went to the SQ trim. It is nice and quiet.
Maybe vortech will eventually make a quiet t-trim or larger blower with helical cut gears, kinda similar to the Paxton Novi 2000. Apparently the clearances are way tighter with those gears vs the straight cut type.
I am happy with my S-trim, SQ version for street driving. It makes more than enough power.
Old Feb 4, 2005 | 02:26 AM
ss#1230's Avatar
i actually wish that my SQ was louder. it is literally silent above 1200rpm, and very very quiet at 1000-1200rpm.
Old Feb 4, 2005 | 05:36 PM
LT1runner's Avatar
I was in the middle of making a decsition to step up with the Z. The T-Trim being the biggest piece. Running through the heads again and choosing a new cam, I figured the next thing to look at was the blower. There will be that noise I'd have to listen too
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
Brady
Jul 29, 2002 10:30 PM
