Rebuild question
Old Dec 12, 2003 | 08:08 PM
DJ:BOTA's Avatar
From: NEPA 15min to stroudsburg, 30min to A-town, 45min to Wilkes-Barre
Rebuild question
Well, the time has come. I'm getting some plans together for the rebuild. Will the stock crank and rods handle 500rwhp?
Old Dec 12, 2003 | 08:35 PM
97WS6SCharged's Avatar
The rods will probably hold up if you use good bolts, but I personally wouldn't chance it on the crank.
Old Dec 14, 2003 | 01:08 PM
Rival's Avatar
the rods will fail before the crank. There have been people who have taken the stock rods and crank to 500 rwhp. Or real close too it. But I would not do it. I would be afriad to beat on it because I think they won't hold up too long. I would buy some eagle I or H beams and a new cast crank if I was shooting for 500rwhp. Maybe get the stock crank checked out if you really want to use it. But I would definately shell out the 300 for the I beams. It not something to lose sleep over.
Old Dec 14, 2003 | 05:51 PM
MEAN LT1's Avatar
I agree you can use the stock rods at that power but I also would swap out the the bolts for some arp's while you have the motor out. Although I have sen alot of peope make 500rw+ with the stock cranks and rods+bolts so I guess it all depends on the luck of the draw. But to be safe I would change out the bolts.
Old Dec 14, 2003 | 07:43 PM
jkbadz28's Avatar
I would go 500 rwhp with the stock crank all day. The rods would be way out of the question. Hell Jason Warren is running mid 9's with the stock crank still.
JK
Old Dec 14, 2003 | 08:02 PM
SMOKNZ's Avatar
My 355 has been around now for 2 years on the stock crank and rods w/ ARP bolts pushing 540+ to the tires, and I'm using it again this spring until I finish my 383.
Bill
Old Dec 14, 2003 | 08:43 PM
DJ:BOTA's Avatar
I see about 50/50 here so far. Keep the advice coming.
Old Dec 14, 2003 | 08:56 PM
rskrause's Avatar
Moderator
Crank = Y
Rods = N
Rich Krause
Old Dec 15, 2003 | 11:52 AM
BBoyce's Avatar
Would Eagle SIR rods be better than stock? I'm slowly getting parts together for my own rebuild.
Ben
Old Dec 15, 2003 | 04:20 PM
94SLUG's Avatar
Why risk it buy some eagle I beam rods and a steel crank. Stock crank yes rods no.
Old Dec 15, 2003 | 04:46 PM
engineermike's Avatar
I have a 350 one-piece rear seal, forged 1053 steel GM crank that's offset ground to a 3.50" stroke that I'm trying to get rid of.
http://www.sdpc2000.com/cart.asp?act...id=335&pid=327
$250 if you're interested.
The mild offset grind only pushes the piston up 0.010" in the bore, so unless your block is "zero decked", it won't cause a problem.
wrenchheadmike1@yahoo.com
Mike
Noenav
Mar 1, 2019 07:38 AM
Sergio
Jan 27, 2016 04:27 PM
armedtrigger
Feb 24, 2015 08:30 PM
Brandon Wittmer
Dec 20, 2014 09:51 PM
