quick question on my blow off valve
Old Feb 7, 2004 | 10:52 AM
blownbird01's Avatar
I have an ati p1sc 12# kit. I was wandering if I can vent my blow off to the atmosphere without any problems instead of back into the intake?
Old Feb 7, 2004 | 11:34 AM
Mike383LT1's Avatar
blow off
yes you can but you need to move your maf to the pressure side of the intake. right now you are pulling the air through the maf and it is what they call metered air, by moving the maf you will be able to vent it to air instead of back into the intake
Old Feb 7, 2004 | 12:01 PM
Why would the maf have anything to do with venting the blowoff to the atmosphere? I was going to just plug the hole that the blowoff goes into before the blower and allow the blowoff to just vent under the car. I'm not sure why this would hurt anything.
Old Feb 7, 2004 | 12:13 PM
Mike383LT1's Avatar
blow off
because when you pull the air through the maf it is what they called metered (the computer has accounted for it ) that is the reason the tube running off the surge valve is ducted back into the intake after the maf if you cap the hole and vent to air it will run like s***. but if you move the maf into the intake after the intercoolers you are know blowing through the maf and the surge valve is no longer a problem with the metered air and you can vent to air not to mention the car will idle a little better set up this way
Old Feb 7, 2004 | 12:28 PM
if I move my maf, will I have to get the car tuned again? I've heard that the maf will max out on the pressure side. I don't have a shop around me to dyno tune yet. I can only do mail order right now. Thanks for your help.
Old Feb 7, 2004 | 12:31 PM
Mike383LT1's Avatar
maf
i've been told you have to do nothing but dont hold me to that you can try pcm for less or one of the same they will tell but once again i dont beleave you have to touch it
Old Feb 7, 2004 | 12:32 PM
thanks again for the info
Old Feb 7, 2004 | 12:37 PM
Mike383LT1's Avatar
blow off
no problem let me know what it sounds like sold my blower before i had a chance to try
Old Feb 13, 2004 | 07:23 AM
94 NO TOP Z's Avatar
The MAF should be reading the same amount of air on the pressure side. You shouldn't need a re-tune.
Old Feb 13, 2004 | 07:35 PM
TimbrSS's Avatar
With the mods you have, I'd definitely get a dynotune, rather than relying on mail order. try here: http://www.westol.com/lpavtis/
94Form
Feb 10, 2015 11:23 PM
Jazsun
Dec 29, 2014 12:14 PM
