questions on 600b
Old Oct 5, 2008 | 03:31 AM
z28maro's Avatar
questions on 600b
i may be able to pick up a older oil fed p600b for pretty cheap. just wondering if there were any common problems with this kit and if its possible to swap it with a p-1sc later on?
Old Oct 5, 2008 | 10:36 AM
bski224's Avatar
How cheap is it. What kind of intercooler?? I have this kit on my LT1. If you plan on putting above 12lbs boost Go with a diff kit. Yes I do believe the head units are just a change thats all.
Old Oct 5, 2008 | 01:49 PM
z28maro's Avatar
its about a grand and comes with the larger intercooler from the bigger kit is what im told. i dont think id go above 12 psi yet with it and it only needs to feed a 355. bski, you have the older model?
Old Oct 5, 2008 | 03:41 PM
bski224's Avatar
yes i have the p600b sounds MINT!!!! if you like the whine, email me bski224@aol.com and I will send you some clips of it running. I wouldnt go above 8lb MAX on a stock block. Also its a good idea to get a dyno tune once install is complete. Ditch the FMU and get larger injectors as well. You will see nice gains with only 6-8lb pulley. Alot of fun to drive and with a good tune safe as well. You should also get fuel press gauge (electric) and a mech boost gauge. Also if you want a GOOD air fuel ratio gauge. Good luck!!
Old Nov 14, 2008 | 10:02 AM
hulettsz28's Avatar
Ive had no problems with mine. ATI makes great products. I would do it, a grand is a steal. Include supporting mods listed above and you will be satisfied? m6 or a4 by the way, just curious?
Old Nov 14, 2008 | 01:10 PM
Sparkz28ss's Avatar
i would say thats a good deal if the head unit is in good shape, I like the p600b
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
