question about "spool up"
Old Sep 27, 2006 | 07:15 PM
Bob-o's Avatar
I've owned a grand national and turbo t bird in the past. Spooling up the GN turbo for launch was easy... hold break, press gas, build spool, launch! I never raced the bird but was never able to build up spool on the street before launch. How do the 6 speed drag racers build the spool up at the strip?
Old Sep 27, 2006 | 11:43 PM
jerminator96's Avatar
Re: question about "spool up"
I just heard about this tonight from a guy, I'm sure he will post later.
But basically you can use a feature in aftermarket computers (like a FAST) that will put an rpm limiter in place at 0mph. You can then hold the gas to the floor and let it bounce off of that rpm, but once you start rolling there is no more limiter.
Someone will get on here and explain it better, but I think you get the idea
Old Sep 28, 2006 | 04:54 AM
AmericanMuscle33's Avatar
normally referred to as a "stutter box"...
Old Sep 28, 2006 | 08:12 AM
RealQuick's Avatar
Two Step
Old Sep 28, 2006 | 10:36 AM
Roadie's Avatar
Originally Posted by RealQuick
Two Step
Yup. I'm running a Delteq and MSD DIS-4 box. The DIS-4 box has a built-in 2-step.
hold down 2-step button. push gas to floor, dump clutch & release button.
Old Sep 28, 2006 | 10:45 AM
JakeRobb's Avatar
Super Moderator
Some people with manual transmissions use a line lock to let them build some boost at the line, but it's not generally recommended.
Old Sep 28, 2006 | 10:50 AM
Roadie's Avatar
I really wouldn't recommend that idea... Either you'd be doing a burnout or frying a clutch. A 2-step is really the only way to build boost for launch.
Old Sep 28, 2006 | 11:24 AM
rskrause's Avatar
Moderator
I don't know much about tubos, but does having the revs up under no load (even with a WOT) build much boost? Doesn't seem like it would???
Rich
Old Sep 28, 2006 | 11:38 AM
Roadie's Avatar
Rich
It's all about air flow, which you don't get with the throttle blades closed. You rev limit and open the throttle blades to use the engine as a big air pump, which spools the turbo.
without the heat and pressures of the engine at full load, you won't spool enough to reach full boost, but you will get the turbo spinning a whole lot faster than it would be at idle and will be able to launch under boost.
Old Oct 1, 2006 | 11:29 PM
Rodrigues's Avatar
2 step is a must (aftermarket PCM is a definite plus) but other than that its all in the timing.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
cmyname1
Feb 19, 2015 08:38 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
TA76
10
Jun 21, 2002 02:16 PM
