Pulley replacement - P1SC
Old 03-22-2007, 12:24 PM
Ultra_Dog's Avatar
Does the head-unit P1SC have to come off the car to replace the pulley? Can it be removed/replaced while on its engine mounts? I'm thinking of changing from the 8# to a 12# pulley.
Ultra_Dog is offline
Old 03-22-2007, 01:15 PM
markinkc69z's Avatar
Plan on removing the head unit for installation. It not too tough.
Tip, use an impact for pulley bolt removal/installtion and Loctite 262 on the threads. If the pulley is stuck you can use heat from a propane torch on the pulley to help it off. Don't direct heat towards the seal.
Torque needs to be about 65/70 ft/lbs or about what you'd put on a lug nut.
markinkc69z is offline
10-31-2016 11:09 AM
Rde Bandit
03-21-2015 10:17 PM
cyteone
02-07-2015 06:04 PM
Jason Short
01-19-2015 06:34 PM
1LEThumper
07-14-2003 12:45 PM
Quick Reply: Pulley replacement - P1SC
