Pulley replacement - P1SC
Old Mar 22, 2007 | 12:24 PM
Ultra_Dog's Avatar
Does the head-unit P1SC have to come off the car to replace the pulley? Can it be removed/replaced while on its engine mounts? I'm thinking of changing from the 8# to a 12# pulley.
Old Mar 22, 2007 | 01:15 PM
markinkc69z's Avatar
Plan on removing the head unit for installation. It not too tough.
Tip, use an impact for pulley bolt removal/installtion and Loctite 262 on the threads. If the pulley is stuck you can use heat from a propane torch on the pulley to help it off. Don't direct heat towards the seal.
Torque needs to be about 65/70 ft/lbs or about what you'd put on a lug nut.
Rde Bandit
Mar 21, 2015 10:17 PM
cyteone
Feb 7, 2015 06:04 PM
Jason Short
Jan 19, 2015 06:34 PM
1LEThumper
Jul 14, 2003 12:45 PM
