Project "Butt hurt"
Old 01-02-2018, 01:46 PM
RealQuick's Avatar
Project "Butt hurt"
Currently building a kit for a member here, but he would like to remain anonymous. The plan is make hellcat, ZL1 and GT500 scratch their heads and say "I just got drug by a what?"
Goal is 850-900rwhp
Build is as follows:
Stainless turbo kit Keeps a/C (On3 8883 turbo, JGS 60mm gate, 3.5 to 4" DP, 5"IC, 3.5" cold side)
385ci
Block: half fill with hard bloc, splayed billet 4 bolt mains with a main girdle.
Crank: Callies Stealth 3.75"
Rods: 6" Eagle H beam rods with ARP L19 rod bolts.
Pistons: SRP -16cc dished forged pistons tool steel taperwall wrist pins - 10.3:1 scr
Custom Comp Cam 236*/246* @ .050 .600"/.610" 113 LSA cam
Comp R-series lifters
Heads: fully ported LT1 heads (LE3) 295/195 @ .600 lift
AFR hydra rev kit
Fully ported LT1 intake
AS&M Monoblade TB
Kevko Road Race Oilpan
Melling hv/hp oil pump
B&M oil cooler with thermostatically controlled fan
Dual in tank fuel pumps stock fuel lines and adjustable fpr
Injectors 120# high impedence injectors (willing to change to whatever will work)
Trans: Faceplated T56
McLeod street twin clutch
Pro 5.o shifter
Rear: Strange S60 with 35 spline detroit locker 3.54 gears
Attached Thumbnails Project "Butt hurt"-.jpg   Project "Butt hurt"-b.jpg   Project "Butt hurt"-1.jpg   Project "Butt hurt"-2.jpg   Project "Butt hurt"-3.jpg
Project "Butt hurt"-4.jpg   Project "Butt hurt"-6.jpg   Project "Butt hurt"-7.jpg   Project "Butt hurt"-8.jpg   Project "Butt hurt"-9.jpg
RealQuick is offline
Old 01-02-2018, 02:07 PM
RealQuick's Avatar
Re: Project "Butt hurt"
more...
Attached Thumbnails Project "Butt hurt"-13.jpg   Project "Butt hurt"-14.jpg   Project "Butt hurt"-15.jpg   Project "Butt hurt"-16.jpg   Project "Butt hurt"-17.jpg
Project "Butt hurt"-18.jpg   Project "Butt hurt"-19.jpg   Project "Butt hurt"-20.jpg
Old 01-02-2018, 04:01 PM
87Aerocoupe's Avatar
Wow that's bad ***, how much does a kit like that cost, man I wish it was me!!!
87Aerocoupe is offline
Old 01-02-2018, 05:15 PM
RealQuick's Avatar
Thanks. I am not a sponsor anymore so I can't discuss. Some strategic internet searching may get you some info. The recipient of this kit frequents this site.
Old 09-07-2018, 04:21 PM
Got my turbo kit and the quality and craftsmanship are impeccable now I'm just waiting for my engine builder to finish the engine.
Old 09-07-2018, 07:30 PM
RealQuick's Avatar
Glad you are making progress and thanks for the words! Keep me posted!
Old 11-30-2018, 10:42 AM
Update the engine is at the machine shop, the block work is completed, bored .040 over, deck plugs, forced pin oilers, decked block, half filled with hard blok, splayed billet main caps, align honed, plate honed ARP head & main studs, block o-ringed. Callies Dragonslayer 4340 crank, Eagle 6" 4340 H beam rods with ARP L-19 cap screws and SRP forged -16 cc dished pistons all coated with appropriate thermal barrier, dry film lubricated or oil shedding coatings, internally balanced, with Fluidampr and McLeod Street twin clutch.
I have AFR 210 Eliminator heads and I will have additional porting done to maximize them further and the combustion chambers and exhaust ports will also be thermal barrier coated, shaft rockers Supervictor EFI intake and a yet to be determined custom cam with Comp Cams short travel Hr lifters or possible a TL solid roller cam.
Kevko 7 qt road race oil pan with baffles and trap doors with a Melling hv/hp pump and a B&M oil cooler with built in cooling fan.
Here are some pics from the machine shop.
Old 11-23-2022, 06:47 AM
blown94's Avatar
Did you ever get this project on wheels?
blown94 is offline
stroked94T/A
01-06-2007 11:38 PM
ProchargedZ
05-17-2006 06:35 PM
stroked94T/A
12-03-2005 09:06 PM
1982z28with18s
07-16-2005 05:05 PM
MongooseZ
12-15-2003 08:29 PM
Quick Reply: Project "Butt hurt"
