Programming out hesitation on tip-in? (big injectors)
Old Jun 27, 2005 | 10:34 PM
engineermike's Avatar
Here's the combo:
383, 8.3/1, 224/236-114 cam, AFR 210's, T-76 GTS turbo, aftercooler.
I'm running the stock '95 ECM, LJ's impedence converter, 84 lb/hr injectors, a descreened MAF on the pressure side of the turbo, and using TunerCAT to tune it.
I have 2 problems I can't seem to program out:
1. When I abruptly give it throttle, the A/F ratio jumps to 18/1, and the engine hesitates, sometimes backfires.
2. When the motor warms up, it won't start without giving it some throttle.
Any ideas on what I should do with the programming?
Thanks,
Mike
Old Jun 28, 2005 | 05:20 AM
Lisa33's Avatar
Re: Programming out hesitation on tip-in? (big injectors)
Looks we have very simular setup exept for the turbo.
Had the same problem when i installed the low Z injectors,
In tunercat:
I raised the MAF1 table around 5-8% in the area 8-22 g/sec. Dont really understand why that worked but it did
Lowered the initial/crank start up A/F in the 40-1xx degrees area widh aprox 10-15% (scaled widh 0.88 for example)
Set the injector offset vs voltage flat from 10-16volt (used the 13,5volt value)
Thats how i solved the problem.
Old Jun 28, 2005 | 09:48 AM
RealQuick's Avatar
Mike, are you running a monoblade?
Old Jun 28, 2005 | 10:11 AM
No, I just have a 52 mm TB.
Lisa, I can't find the "initial/crank start up A/F" in TunerCAT. What do you use to tune?
Mike
Old Jun 28, 2005 | 10:21 AM
RealQuick's Avatar
In tunercat:
Old Jun 28, 2005 | 11:08 AM
Schurters LT1's Avatar
Mike
I think that is in the new V of TC, i am sure i have seen that table....
-J
Old Jun 28, 2005 | 03:34 PM
Lisa33's Avatar
you need a newer definiton file, The correct name on the table are
Initial startup AFR enrichment VS colant
I also decreased
1st primepulse vs coolant
2nd primepulse vs coolant
widh 40-50%
ake eliasson
Z28Freak86
Apr 30, 2024 05:37 PM
TitoPR221
May 26, 2015 12:20 AM
jocamino
May 14, 2015 07:37 AM
Jul 4, 2005 05:00 PM
