procharger or vortech
Old Sep 29, 2006 | 10:44 PM
  #31
rskrause's Avatar
Moderator
Re: procharger or vortech
Just to clarify, I am talking about HR street setups running on pump gas. And when referring to stock castings, I am talking about the typical ported stock castings, not some set of heads that someone spent a hundred hours reworking.
Rich
Old Sep 30, 2006 | 01:37 AM
  #32
Lisa33's Avatar
Originally Posted by 95 Z/28 LT1
How does the 6X2 belt setup work? Do you simply use 2 - 6 rib belts in place of a 12 rib?
Yes, much easier to find 6rib belts than 12 ribs here.
Old Sep 30, 2006 | 10:15 AM
  #33
Sparkz28ss's Avatar
hell with a supercharger...
gt76 is all you need
Old Sep 30, 2006 | 10:18 AM
  #34
T/A KID's Avatar
I will have to find it but a Car Combination motorsports did a 383, 236/248 114 cam, spinning the D1SC to max RPM, with gasket matched Trickflows, and a Ported intake with a 58mm, Through a 6-speed, air to water intercooler, and this was A Total Street Car. made 700RWHP an like 640RWTQ.
Old Sep 30, 2006 | 10:26 AM
  #35
rskrause's Avatar
Moderator
D1SC flows 1,400cfm, 40% more than an S-trim!
Rich
Old Sep 30, 2006 | 11:30 AM
  #36
T/A KID's Avatar
Ok, that makes since now Rich, I thought you was saying you haven't seen anyone make 700RWHP with Trickflow heads, But you ment with a S-trim
Also on a Side not I have always heard this and I just want to clearify since we are talking about Procharger VS Vortech
P1SC = S-Trim
D1SC = T-trim
F1 = YSI
Old Sep 30, 2006 | 11:52 AM
  #37
jmh96z28's Avatar
So basicly, if I get afr heads I will have to get a lt4 intake. What about trickflows, will those match up to a lt1 intake
Old Sep 30, 2006 | 12:16 PM
  #38
bowtiepwr's Avatar
>AFR has LT1 heads too...
http://www.airflowresearch.com/180sbc_lt1.php
I (thought I) heard that there is a way to match up LT4 heads to LT1 intake.
If not I'm sure people here can lead you in the right direction.
Old Sep 30, 2006 | 12:24 PM
  #39
rskrause's Avatar
Moderator
Yes, I meant with an S-trim.
S trim = 1,000cfm
T trim = 1,200cfm
YSi = 1,600cfm
P1SC = 1,200cfm
D1SC = 1,400cfm
F1 = 1,525cfm
F1R/D1R = 2,000cfm
Rich
Old Sep 30, 2006 | 12:30 PM
  #40
bowtiepwr's Avatar
Originally Posted by rskrause
F1R/D1R = 2,000cfm
Rich
>hey don't forget Vortechs:
VORTECH V-24 Z-TRIM SUPERCHARGER
The next generation in big blowers
Modular, extremely robust drive
4.25:1 internal step-up ratio
unprecedented strength and durability
Fits engines up to 1,400*+ horsepower
Maximum airflow: 2,000* CFM
Maximum boost pressure: 32 PSI
Absolute maximum impeller speed: 60,000 RPM
Adiabatic efficiency: 77%
Available with straight discharge and clockwise rotation only
Old Sep 30, 2006 | 01:49 PM
  #41
CALL911's Avatar
Thats friggin crazy talk for a street car. I am sure someone will argue with me otherwise though.
Old Sep 30, 2006 | 02:18 PM
  #42
rskrause's Avatar
Moderator
I don't think a SB street car could make use of 2,000cfm. A 383 running 6,500rpm would show close to 30psi with 2,000cfm. Might have a tad of detonation on pump gas! My buddy uses an F1R on his 336ci SBF and sees 26-27psi at ~7,500rpm. The motor runs on C16 (117 MON), which is not exactly practical on a street car.
The 1,200cfm range is good for a small block street car. The S-trim, at 1,000cfm is a little small, but many people have very sweet setups with them. I was very happy with mine when I ran it. I may have already mentioned another buddy who runs an S-trim on his 347SBF and runs in the mid to high nines. Of course, that car weighs only 3,300lbs.
Rich
Old Sep 30, 2006 | 04:19 PM
  #43
bowtiepwr's Avatar
>I only posted this to make it fair with Rich showing the ATI Procharger F1R and D1R, so I figured I should post the Z-trim too
Old Oct 1, 2006 | 01:03 AM
  #44
CALL911's Avatar
Making over 800 RWHP in a street car is really about useless IMO. Athough I know friends back home that are making over 1000 RWHP in their street cars and they would argue that there is never too much power. It pretty much depends on the individual I guess. But at a certain point having to find C16 for examply may become a pain to fill your car on the way to your kids soccer game and back.
Old Oct 1, 2006 | 02:45 PM
  #45
HardcoreRM125's Avatar
Thats why you emulate what GM did with their Grand Nationals, and make compression rediculously low, and make boost rediculously high, with a great bottom end.
There a guy that lives by me running 19 ( Eeek!) psi pump gas on a 9.0 to 1 LT1. It is as rediculous as it sounds. And when it makes boost, whether it is in 1st, 2nd, 3rd, or 4th gear, the tires break loose without his drag radials. Is running a 9" with 4.10 ( maybe 4.11)'s ?, M6, its a freakin beast.
Another guy is trying to get his stang going with a 10.1:1 compression for 18 PSI, on E85. In the process of working out the bugs with a double pumper, and trying to find a tuner knowledgable with E85. Should be a ****ing monster when its done.
