Problems installing Crane HI 6R
Old Jun 17, 2003 | 04:29 PM
94SLUG's Avatar
The white wire that comes from the box where does it splice into. Instruction say the White points trigger wire connects to the OE wire that was removed from coil. Well I have only three wires from coil and none of them go to a module. All three go into a wire harness. So it says hook orange from BOX to + coil and black from BOX to - coil. So which two of the three do I use out of coil. The coil has 2 grounds and 1 pos right? Do I hook the white wire to the other 3rd coil wire. sorry if this is confusing cause i confused myself trying to post this.
Crane says I need part# 6000-6708 External Signal Wire plug? Do I need that?
If you can answer one question its WHERE THE HELL DOES THE WHITE WIRE GO FROM THE BOX?
Bill
Old Jun 17, 2003 | 05:14 PM
t-trimz28's Avatar
Bill,
I just went outside and looked on mine and the white wire eventually goes to the harness on the coil, but goes through another harness first.
Don't know if that helps.
Chris
Old Jun 17, 2003 | 05:41 PM
94SLUG's Avatar
Yes that does help some. Is the other harness 4 wires that goes into a little black box looking thing/dew module? Crap a picture is worth a thousand words. So the white wire has 1 or 2 splices connectors? On your coil does the white wire go to the plug with 2 wires or 1 wire?
Bill
PS Crane Customers services= NO HELP!
Can anyone just write brief install guide? Theres only one wire hampering me and its the white one.
oldschool
Feb 9, 2016 09:21 PM
nikolt1
Feb 27, 2015 09:10 PM
thenewkid
Nov 27, 2014 09:41 AM
Don 97 SS
Jul 11, 2005 08:50 AM
Chrisdude
Jul 24, 2002 02:25 PM
