Will vortech sell the impeller alone for a S-trim?
Old Jun 14, 2003 | 06:24 PM
Highlander's Avatar
Will vortech sell the impeller only for an S-trim or maybe a T-trim. Mine is all fu(ked up.. so I need a new one or mount it as it is...
Let me know
Old Jun 14, 2003 | 07:30 PM
engineermike's Avatar
Although it would be cool to install a T-trim impeller in an S-trim housing, it can't be [easily] done. The inlet (eye) of the compressor is 1/4" larger on the T-trim, so a T-trim impeller physically won't fit in the S-trim snail.
Mike
Old Jun 14, 2003 | 10:50 PM
Highlander's Avatar
It can be bored, at least that is what I think they do.
Old Jun 15, 2003 | 09:59 PM
Check this out:
www.vortechsuperchargers.com/tech/exprogv-1.html
Sounds like yours would be a 'B' class exchange, getting you only $400 towards a new T-trim unit. The head unit alone is $2150 at superchargersonline.com, probably less at TByrne.
Old Jun 15, 2003 | 10:01 PM
Highlander's Avatar
But i would have to buy it at the MSRP and its not fair...
Any other ideas? i will call vortech tommorrow morning.. if not... I will mount it as it is.. It was making 10psi that way and it was running great...
Old Jun 16, 2003 | 11:42 AM
MislMan's Avatar
While you are talking to Vortech , ask them how much a rebuild will cost and how long the turn-around time is. I would not put that SC back on the motor myself. With the damage that has been done I suspect that the impellor has stress risers throughout the parent material. Putting it back on the motor is just asking for the impellor to fly apart BIG TIME and send even more junk down into your motor. You might get lucky, but then again it might cost you a lot of money blowing the motor apart. A rebuild seems like a cheaper way to be sure. Just saying it hasn't blown apart yet is sort of like saying the stock pistons can handle 10 lbs. boost. Some have run this much boost but many have found out the hard way that weak parts can lead to costly repairs.
Later ... Larry S.
Old Jun 16, 2003 | 01:25 PM
Highlander's Avatar
Its forged..
anyways... The aftercooler filtered some big particles... Luckily when that happened I didn't have the elbows connected to the engine.. whew... I saw no metal powder or anything on my intake runners and the car was running great, so I assume that nothing big got in there...
I will call vortech and see..
Old Jun 16, 2003 | 09:57 PM
boosted-lt1's Avatar
Yeah, definately dont put it back on the motor.....SOMETHING IS WRONG!
A 5.0 buddy had an S-trim that looked similar and took a look at it cause it was only making 10psi instead of his usual 14psi. He had Vortech rebuild it for some thing around $750. I cant remember what Vortech "said" happened though. It was either the motor had injested something, or the vacume line had popped off the bypass causing major surging.
Old Jun 17, 2003 | 01:58 AM
Highlander's Avatar
I had some surging too though since sometimes the vacuum line popped... but.. if it had surging... shouldn't the impeller be worn on the side that you cant see from back pressure?
Damn 750 bucks is a lot of $ for just a an impeller.. DAMN!!!!
Old Jun 17, 2003 | 09:25 AM
Now I'm not sure if the only thing that was replaced was the impeller. I'm thinking he had new bearings and stuff as well installed. Talk to Vortech directly and they can give you some definite prices and maybe tell what the heck happened to it. Post back when you do find out, I'm curious.
-Scott
Old Jun 17, 2003 | 05:45 PM
Highlander's Avatar
They want $480.00... they will not sell the parts so you can do it here... Damn!!!!
That is a lot of money to stay the same...
Jlo
Jun 24, 2015 11:55 AM
OTL
May 26, 2015 09:34 PM
detroit1994z28
May 14, 2015 12:09 AM
Jlo
Feb 3, 2015 09:41 PM
