Pro Turbo Kits
Pro Turbo Kits
Does anyone have this kit
http://www.proturbokits.com/gmkits.htm
If so can you tell how well it works. your power numbers and such??
I have been looking at this kit and i cant decide whether or not to go Turbo or N/A........i am leaning towards Turbo but im not sure which kit to get.
If anyone out there with this kit could give me some pros and cons about it that would be great.
also how would I go about lowering my compression enough to where i could run over 10 pounds of boost..............
i wanna run somewhere in between 10 and 20........is this POSSIBLE????
thanks
Scott
thanks
Scott
I don't know, if you could get your compression down to like 6:1, it might be possible. Just use the pistons that look like cereal bowls along with the shortest throw crank and the shortest rods you can find.
JZ 97 SS 1500 -- keep me informed of how everything is going would ya??
When you get it done i wanna know how much you made to the rear wheels at what psi. Plus what kind of heads, cam, pistons, etc. you have with that..........thanks
Scott
Scott
Car is a 383, 8.5cr, 230/230 cam, big AFR heads, JE pistons, Eagle rotating assem. The kit is a custom unit, using all larger piping, larger water/air IC, PTE88, BOV and wastegate both venting to atmosphere, 4" DP is going on once I get the other style exhaust housing for the turbo. For now its just a 3" DP.
Jose
Jose
Ah, wastegate to atmosphere... You won't like it, it sounds absolutley horrible if it's anywhere near or in the engine bay. I tried it, but quickly reconnected it back to the exhaust. I love to listen to the turbo spool, you really can't hear it with the gate vented. But this is only my opinion.
Bill
Bill
Originally posted by 97WS6SCharged
Yeah, isn't it the BOV that gives the whistle sound when you shift?
LT1runner
33
Jul 24, 2002 01:19 PM
