Polish the inside of the intake???
Old Jun 18, 2003 | 09:33 PM
Wild1's Avatar
Is there any advantage to polishing the Inside of the Intake Manifold with a supercharged engine? Would the polished inside help the flow of air? Sorry for the novice question.
Old Jun 18, 2003 | 10:36 PM
texlurch's Avatar
Anything you could do to smooth the dry air flow should help; challenge is getting to it. I guess you caould saw it in half, then tig it back together. Extrudehone works well also. This is where they force an abrasive "paste" thru the runners, and it removes metal uniformly.
I would think that it would be cool to be able to watch the airflow thru an intake. I would like to see how it acts when it has to make the 90 degree bend down the runner. Then, by polishing or dimpling differrent areas, you could affect the flow and speed, and increase the port filling...
Old Jun 18, 2003 | 11:09 PM
Wild1's Avatar
That is an interesting idea. If the intake was dimpled in certain areas like a golf ball, you could effectively increase air speed. Hmm.
Old Jun 19, 2003 | 09:24 AM
kmook's Avatar
Advanced Tech Moderator
You may want to join this discussion as the last post goes into polishing the intake manifold.
Old Jun 19, 2003 | 11:45 AM
Wild1's Avatar
Kmook, it seems that they are talking about fuel puddling in the intake port of the cylinder head. It is an interesting discussion. But the air is dry until it reaches the point of the injector. So, puddling or laminating fuel wouldn't seem like a big issue. But I really don't know... which is why I'm asking this question.
Thank you for the lead to that discussion. I subscribed to the thread just to keep track.
Thanks again.
Dmonty
Jun 2, 2015 11:19 PM
Drtryder
Apr 22, 2015 04:17 PM
carl.froehlich
Mar 13, 2015 12:38 AM
thenewkid
Nov 27, 2014 09:41 AM
