PLugs for boost
Old Sep 2, 2007 | 02:47 PM
IROCThisZ28ForLife's Avatar
PLugs for boost
Which would be the best plugs for the tt setup going in...Tr6's? I know i need a colder plug, input please
Old Sep 4, 2007 | 12:45 AM
racer96's Avatar
hey man do a quick search it will come up. thats how i found the ones i wanted to use. i cant think of wut they are or i would just tell ya. but i know there is info on the board. good luck
Old Sep 10, 2007 | 08:53 PM
windsma's Avatar
somewhat off topic sorry, also interested in which plug?
and I know how impossable changing plugs are, prob. not going to happen with custom turbo setup. Has anyone cut holes in the strut tower sheet metal to make it easier.
Old Sep 10, 2007 | 09:39 PM
xxsaint69x's Avatar
AC Delco FR1LS
Old Sep 11, 2007 | 04:39 PM
Kevin Blown 95 TA's Avatar
I use Champion or NGK Racing plugs
Old Sep 13, 2007 | 01:34 PM
mzgp5x's Avatar
I use the Zex power racer (tm) plug. (97ss 383 - D1) B.
Old Sep 18, 2007 | 02:07 PM
93BlackTA's Avatar
Are the AC Delco FR1LS plugs gasketed?
Old Sep 20, 2007 | 03:34 PM
CALL911's Avatar
Personally I would stay away from the NGK plugs. My tuner, and several other top notch tuning FI guys have had issues with them, especially at high RPM's.
Personally I run Autolite's, and have had great success with them. The idea is to get the right heat range plugs reguardless on what you choose for name brand. If you don't know between the two heat options, go for the colder one, at least at first and see how they perform.
Old Sep 20, 2007 | 05:16 PM
Kwiksilverz28's Avatar
NGK TR6 @ 0.35". No issue. Had issue with a coil. Just did MSD's coil kit. No more problem. :-)
Old Sep 20, 2007 | 08:50 PM
How do you tell which Autolites are made by Torch in China?
Old Sep 20, 2007 | 09:46 PM
Z8'S's Avatar
I've always used NGK with no problems whatsoever.
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
Mar 13, 2016 03:39 PM
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
