PCV/crankcase Evac with Drawings, need Help
Guys help me figure out my PCV/ crankcase Evac setup on my LT1 D1SC motor.
Here is 4 drawings that I came up with for the setup can I want you guys to explain to me which one would be better and why?????
I didn't draw in VC filters or inserted Check valves b/c frankly I really didn't know where They would be needed. Thanks Fellas.
BTW I have MAD Paint skills, lol.[IMG]IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG]
[IMG]
[/IMG] [IMG]
[/IMG] [IMG]
[/IMG]
Re: PCV/crankcase Evac with Drawings, need Help
You really need to post this on the "Forced Induction" forum. The guys there solve this problem every day. Anyone who doesn't have a blower is not likely to know the answer, or know which setup works best.
I'll move it for you.
Thanks Fred, does anyone have advice on this??? Procharger told me not to run the PCV setup, but I have also heard otherwise. I have researched this a lot and I see a lot of controversy.
Setup #4 is the best in my opinion. If you vent to atmosphere you will get foul smells. Also the supercharger intake does not provide enough vacuum at idle to vent the crankcase.
Well I got some really good info from someone, and it was to run the stock PCV valve from the driverside of the intake (it already has a Check valve in there) into a Catchcan and then run a Line from the can into the suck side of the blower.
I was told not to worry about breathers or anything on the valvecovers,
and to plug the hole in the passenger side Valvecover?????
I have never seen anyone do this but I trust the guy who told me it would be ok.
Why would you need a check valve if that line never sees boost? In other words your drawing air from the lifter valley and sending it to the suck side of the blower through a catch can.
I suggest you leave the driver side pcv valve and rubber line hooked up as though it were stock(it hooks into the front of the intake manifold for vacuum and draws harmful blowby from the lifter valley on the driver side of the engine).
Then I would run the passenger side breather hose through an air/water separater(check out projecttransam.com for details) to the suck side of the blower. There is a picture at the bottom of my cardomain site.
I've run this setup for 25,000 miles and it works great. Also you don't have to add a catch can to an already overcrowded engine bay. I get about 2 or 3 drops of oil in the separater when I wind it up to 6400 rpm. This is because the blower intake makes alot of vacuum at high rpm. No oil leaks, no pressure in the crankcase, and I'm running 6000 miles between oil changes.
If you seal up the motor properly you only need a PCV. Using a breather just opens up the motor to suck moisture in and collect on the inside of the valve covers. If this is so wrong then why would GM do this for motors going 100,000miles?
The air/water seperator is a good idea, but for any of these systems to work the motor needs to be 100% sealed and check valves installed so you prevent anything from entering the motor other than thru the induction system.
Bret
Bret
Yep Bret is the one who helped me out on this, it seems rather simple and would not be as cluttered as some of the other setups I have seen.
Since the stock PCV setup contains a check valve Bret told me to direct it to the catchcan then into the suckside of the blower, and to just use a plug to plug up the hole in the passenger side Valvecover.
I have always considered a Catchcan the same thing as a air/water seperator??
Bret
Bret
Every stock PCV system I've ever seen has a breather filter or some way to allow fresh clean air into the crankcase. Even back in the 70's my Ford Econoline Van (******* Wagon)
had a breather filter inside the big round air filter can.BTW you make great cams. When I called Comp Cams two years ago they compared their cams to yours.
There is nothing wrong with using a catchcan. They are just usually more expensive and bigger as far as space goes
http://www.jegs.com/webapp/wcs/store...tegoryId=10053
I know I can get one cheaper at a local parts store but I like the design and mounting spots on this one. I plan on mounting it near Suck side of the blower so it can be a simple transition.
What do you guys think.
It seems having the system 100% sealed makes the actual "crankcase" evac more efficient. If you have an outside air source present (i.e. breather(s)) you may only be sucking air through the breather and into you're catchcan/vacuum pump/etc. minimizing or atleast reducing the actual crankcase gas/pressure removal which is what you want to be removing.
I mean...take you're home vacuum cleaner...set it to the hose extension, and cut a couple holes up on the side of the hose, it doesn't suck anything through the nozzle anymore does it? Seems to be a similar principle...Just my $.02.
Originally Posted by 97WS6Pilot
...I suggest you leave the driver side pcv valve and rubber line hooked up as though it were stock(it hooks into the front of the intake manifold for vacuum and draws harmful blowby from the lifter valley on the driver side of the engine).
I have my drivers side of intake looped to the connector next to it, then ive got the passenger side of the throttle body capped off. i run the hose from the passenger valve cover to the intake side of the blower. I am planning on running another passenger side VC on the drivers side and teeing them together and then to an oil catchcan, and then tying that into the suck side of the blower between it and the filter. it seems to keep the motor the most sealed while allowing it to pull the most out. while also keeping oil from making it into the the supercharger.
From what I have seen, There is quite a Few ways to get Crankcase evac out of the a Motor effeciently. I have talked to several People and shops about this and something I was told that would work well is picture number 1.
Exotic Performance plus, VRE, Shane at thunder racing, Stenod, all told me I really didn't need a PCV setup b/c it was basically for emissions and I should just use a Pipe plug to plug it up. Here is one of Stenods customer cars they just did and this guy drives this on the street often even with the Glide http://ls1tech.com/forums/showthread...&highlight=PCV
Some peope say, " well you need to change your oil more frequently" and I change mine every 3000 miles regardless.
I still have some things to think about with the PCV setup but I may go with Bret's idea still since it seems like less work and just as Effecient
