Part # needed for JE rings
Old Feb 18, 2004 | 09:17 PM
Grover's Avatar
Does anybody know the part number for the JE "Hardened Nitrous Series" rings for a 4.030 bore? I looked in their catalog but didn't see these listed.
What I found was the 8200 series 1/16 1/16 3/16 HNS Ring set, with part # J820F8-4030-5.
Is this correct?
Old Feb 18, 2004 | 10:02 PM
rskrause's Avatar
Moderator
Re: Part # needed for JE rings
Is this correct?
Not sure what you are asking. Right for your piston? What piston?
Rich Krause
Old Feb 19, 2004 | 06:40 AM
Grover's Avatar
Well Rich, I am collecting part # and prices for my 383 built.
Here are the parts I plan on using:
  • Callies Crank 3.75" stroke (either Dragonslayer or Racemaster)
  • Callies Billet I-beam rods
  • Callies Billet 4 bolt splayed main caps
  • JE "Extreme Duty" -31cc domed pistons for a 5.7" rod
  • AFR 220cc heads with 76cc chambers
  • Custom turbo cam
  • 80mm turbo
I am looking to make 650-750 rwhp on pump gas (not all the time) thus the low compression ratio.
Old Feb 19, 2004 | 06:47 AM
rskrause's Avatar
Moderator
  • Custom turbo cam
  • 80mm turbo
I think you would do just as well with the standard rings JE supplies, but if you want the HNS rings, just call them for a correct PN. Sounds like very good parts. I'd upgrade the wrist pins though. Again, call JE for advice. They are quite helpful.
Rich Krause
Old Feb 19, 2004 | 11:39 AM
Grover's Avatar
Okay, will do. Thanks Rich.
Old Feb 21, 2004 | 03:50 PM
Hot Rod Hawk's Avatar
Chad heres a nitrous/boost ring package I've used.
Childs&albert numbers for each ring location. Upper is a tool steel, second is a zero gap taper face, third is standard tension oil control.
rl-116x4.035 ................ g-2000 steel alloy
zgtf-116x4.030 ............ ductile taper face zg
os-316x4.030 ............... oil control rco std
Set number would be rs-53zx4.035
That Je number is for 1/16, 1/16, 3/16 ring package
also a tool steel type upper, non-moly second, hard carbon oil.
Yes its capable of withstanding greater cylinder temps with increased resistance too fatige [sp?] and failure. Cross hatch finish is very important with either of these two, be sure your shop has the correct stones.
Also of note, for brake in you need to run a very light single weight oil for the first 10 minnutes to seat the tool steel stuff.
Old Feb 23, 2004 | 10:59 AM
Chad
I checked on those Hellfire rings today. I couldn't find them in my JE catalog at home yesterday.
Federal Mogal is the manufacture of Hell Fires, your part number would be R19100-35 for a 4.035 file fit 1/16, 1/16, 3/16 package.
Check your PM's.
Old Jun 13, 2004 | 10:15 PM
Highlander's Avatar
what do you mean about the wrist pins rich?? what do you recommend there? i have the ones that came with my pistons...
Old Jun 14, 2004 | 09:16 AM
RealQuick's Avatar
Subscribing...
Old Jun 14, 2004 | 10:04 AM
rskrause's Avatar
Moderator
Sounds like you are building a very powerful combo. If you already bought the pistons and have wrist pins I am not sure it would be worth it, but what I was referring to was getting an upgraded wrist pin.
Rich
Old Jun 14, 2004 | 10:06 AM
Highlander's Avatar
Pistons are the same from my previous setup... IIRC they were the "upgraded" wrist pins...
my plan is 700rwhp or a tad more...
Old Jun 14, 2004 | 12:38 PM
MEAN LT1's Avatar
Your planned horsepower goal sounds alot like mine. I was wondering what you were using for fuel requirements? and is this a "street car" or strip?.
Old Jun 14, 2004 | 04:10 PM
Highlander's Avatar
100% street...
For now.. 255lph and Boost a Pump... 75# inj (if they are enough)
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
