PA Racing K-member?
Old Nov 22, 2006 | 12:55 PM
  #16
cwaldt's Avatar
I'm happy with my BMR Fabrication K-member for my BBC set up.
Old Nov 23, 2006 | 09:06 PM
  #17
NOSCaMaRo's Avatar
Originally Posted by TransAm396
thats not to bad at all..i like the UMI unit but it looks like it takes up just as much room as the stock one..and Im looking more for room than JUST weight savings..
I think as far room they are all similar. The UMI one does have a extra tube but I don't see where that would affect where turbo piping would go.
Old Nov 25, 2006 | 06:52 PM
  #18
slimdawson's Avatar
I hope your PA is better than mine was. I've seen plenty of people upset about the quality of them. Think they were mainly 3rd gens though.
Unreal weight loss claims, shoddy welds, and non fitment issues with control arms were my problems.
Old Nov 27, 2006 | 12:07 PM
  #19
cwaldt's Avatar
Here are the specifications copied from PA Racings website
K-member Specifications:
1.150" x .120" mildsteel 1.150"x .083 4130N Chromoly seamless DOM tubing
Any motor/chassi combo can be built (call with measurements)
Lightest Best fitting k-members on the market most possible header room
Works with stock a-arms or any aftermarket a-arms (minor modifacations required)
CNC laser cut 3/16" mounts
Formed motor mounts with optional Solid direct block mounts available
Powdercoated using the highest quality
Can be built and used on all sorts of applications including street, road race, autocross, or drag strip
Using our tubular K-member and upper/lower a-arm & coil over kit, expect a weight reduction of up to 85 lbs. Combine this with a Santhuff or Afco spring/shock combo and a lightweight Pa Racing rack & pinion kit and front brake setup and lose over 150 lbs. off the front end!
Grade 8 shock mounting hardware Available (extra)
Fully assembled and ready to install
100% jig welded! All parts are Jig built in-house!
Made in USA with best materials available!
STRONGER, and LIGHTER than stock! (loose over 75lbs)
I highlighted the weight loss in bold. I'd like to see you loose over 75 lbs by just chaning a k-member. It just isn't going to happen because the stock k-member doesn't even weigh that much.
Old Nov 29, 2006 | 05:34 PM
  #20
lt1camaroman93's Avatar
I've only used 1 PA k-member. It was in for a SN95 Stang and it fit like a glove with great welds and quality.
Old Nov 29, 2006 | 06:49 PM
  #21
NOSCaMaRo's Avatar
Yep it is impossible, the stock K-member only weighs 57 lbs
Old Nov 29, 2006 | 07:24 PM
  #22
lethal93ta's Avatar
my stock K member was 54 lbs, the PA racing one I got is 22 lbs so I lost 32 lbs with the K member, I lost another 8 lbs with the tubular upper and lower A arms, those are spohn's, so 40 lbs off the front end but thats still no where close to what there saying.
97blackformula
Aug 27, 2015 06:02 PM
Slayer
Aug 17, 2015 03:55 PM
karpetcm
Aug 14, 2015 03:02 PM
Louey
Pacific
Aug 7, 2015 01:47 AM
Boss002
Jul 24, 2015 10:47 AM
