opinions on supercharging
hey all.....had a few questions for the FI gurus......i think i'm going to blow my z-28 and i have a few questions.
suspension, tranny and rear-end are accounted for.
1. i originall wanted 383 stroker w/N2O.....was thinking or going 355 with S/C.....what advantage/disadvantage does 355 have over 383?
2. what is a good fuel system and what pound injectors to use.
3. definately plan on going with intercooler.
the goal is basically a 10 second any weather condition streetable car that will not travel long distances. the blower being considered is the ATI P-1SC with I/C.
any help and opinions will be greatly appreciated.....CM is going to be doing the motor when i decide.
Re: opinions on supercharging
Originally posted by IDOXLR8
If you do a search you will find alot of useful info.
Centrifugal superchargers build boost nearly linearly with rpm. So, at low rpm, they won't build much boost. A 383 complements this characteristic well by building torque at low rpm where the supercharger isn't doing much.
Mike
Mike
so it looks like the 383 is going to be the choice as the 355 won't make as much down low and i would guess that you'd have to rev it to the moon to get anywhere. thanks for the opinions guys. what level boost would be a good bet that won't exceed the limits of the stock pcm.....i was thinking about 12psi.
With an Acceleronics impedence converter box, I seriously doubt you'll approach the limits of the stock PCM. You can run very large injectors (at least 72# = 1000 hp) with the converter.
Mike
Mike
