What do most people do, turbo or super?
Im starting to look into a turbo or super. What do most LT1 people do? Anyone know of any links for FI newbs? I want to greatly research this before I proceed(and I dont have the cash
Judging by your mods you'd probably be better off building a nice shortblock. As for popularity the superchargers far out number turbos, mainly because there are 2 large manufacturers that make an excellent product. For turbos you have several small companys that build kits that usually have to be modified to make them work.
Actually I was thinking(sorry I really dont know much about FI) about running a boost controler, keep it as low as I can then when the need comes turn it up.
Then you best have an aftermarket ECM, or have different programs ready for the stock ECU everytime you change the boost. Otherwise you could always program for the highest boost and then run the thing pig rich on your lower boost settings (loose alot of power). With $ being a concern as you previously stated I'd stay away from the boost controller.
I can get you into a STS turbo kit for around $3000. You can run low boost on what you have and then turn up the boost as you can afford to modify the rest of the car. Our system goes on in about 3 hours and we gained 12 mph in the 1/4 at 5 psi boost and 14 mph at 7 psi boost on bone stock LT1's. Our 93 is running in the 11's at 4300' elevation with stock heads and cam, 2.73 gears and a 2200 stall. Call if you have any questions.
Thanks, Rick @ STS
801-979-6554
Thanks, Rick @ STS
801-979-6554
Actually car ran 12.1 at 116 mph with a lot of wheel spin on BFG DR's. I'll send you chart and run info to your email. This time is almost identical to what my Chevelle runs on BFG's at 17 psi boost and it runs 11's all day on slicks.
Talk to you later, Rick @ STS
Rick, could you also send me information on the kit. 95_RipperZ@team.camaroz28.com
Also, doesnt the carhave 8.9:1 CR?
Hoping to have our site up in next week or so. Have had hard time getting web guys to get it together so we are just going to do it ourselves. Might not look cool or even work, but at least it is going to get done! If you want to email me, I'll send dyno graphs, pictures, etc and answer questions.
Thanks, Rick @ STS
STSturbos@hotmail.com
Thanks, Rick @ STS
I'm not quite sure why people are obsessed with the turbocharger's ability to "adjust the boost" using a boost controller.
A supercharged car can get the same effect by letting off the gas. That's right! If you don't want full boost, don't use full throttle.
My car makes 14 psi boost at full throttle, but at 3/4 throttle, it only makes 8.
Good to hear from you again Mike.
With the centrifugal superchargers you can control your boost by when you shift too. They build boost linearly so the higher you rev, the more boost they make. If you have 14 psi at 6000, you can probably shift at 4000 and have around 8 psi. Course you have to have a stick or manual valve body.
Don't part throttle positions tend to lean out more than full throttle settings? If not, don't you get crappy mileage just wheeling around town at part throttle?
Hi/low boost settings are cool cause you can run your water injection on the high setting and not on the low so you don't have to have a 5 gallon tank of water. We sometimes run a lockout switch on our truck kits so that you can turn the boost to low setting and then take the key out. That way the kids can't run the wheels off your truck.
Try telling a teenager to only use 3/4 throttle.
Later, Rick @ STS
Later, Rick @ STS
brothaslide
Jan 9, 2016 12:11 PM
LeftoverChinese
Jul 23, 2015 03:57 PM
