Oil Return question?
Old Jan 21, 2008 | 03:14 PM
  #16
subarubill96's Avatar
i got you kinda like a 45* to 45* straight shot deal? -\_ kinda like that?
Old Jan 21, 2008 | 03:19 PM
  #17
jchevy's Avatar
Yeah,just like that
Old Jan 21, 2008 | 06:31 PM
  #18
should work nicely if its a straight shot
Old Jan 21, 2008 | 07:43 PM
  #19
RealQuick's Avatar
Originally Posted by jchevy
Yeah, thats what im talking about, the oil drain will be clocked up about
20* in relation to the ground. Get what im trying to say? The drain wont be pointing straight down at the ground, more toward the oil pan so its more of a straight shot.
This is correct. You kjnow you can buy 45 degree fittings too right?
Back to my statemnt though, think of the oil drain fitting coming out of the turbo straight down... you can angle it ~20-25 degrees toward the oil pan (this is for the oil drain/feed). The water side should be pressureized with water to cool the bearings.
Old Jan 21, 2008 | 07:44 PM
  #20
RealQuick's Avatar
Whoops... I didnt finish reading... you guys figured out the 45 degree fitting thing
Old Jan 21, 2008 | 08:11 PM
  #21
its not my first rodeo jon, i have picked up a thing or 2 in my day mister turbo guru
Old Jan 21, 2008 | 08:21 PM
  #22
jchevy's Avatar
Its my first rodeo and you guys are helping me a ton! Thanks.
If you asked me a month ago I had no intentions of turboing my car. A deal fell in my lap and next thing I know Im trying to figure out WTF is going on.
Old Jan 21, 2008 | 09:17 PM
  #23
ahahah no problem . hell if i knew just one tenth of what i know now back when i got into forced induction id having 3 working cars and be a slightly less poor man. of course, if i knew 1/100 of what jon did, id be making kits myself
Old Jan 21, 2008 | 09:59 PM
  #24
RealQuick's Avatar
I am still learning everyday from guys like engineermike and guys on ls1tech.com! Bill, shoot me an email, how are things?
Jon
Old Jan 24, 2008 | 01:38 PM
  #25
snorkelface's Avatar
Originally Posted by RealQuick
Watercooled means its a ball bearing turbo. It takes oil in and out for lubrication, and on the sides the coolant/water goes in and out for cooling.
The prehistoric turbos are the oil only ones (standard journal bearings).
PM 182z28with18s as he runs a BB turbo. Ask him how his cooling setup is.
How do I know if my turbo is a ball-bearing unit?
Old Jan 24, 2008 | 02:10 PM
  #26
RealQuick's Avatar
As far as I know, all ball bearing turbos require water cooling. You should have a oil inlet and outlet on the center cartridge, and then 90 degrees from that should be a water inlet/outlet.
You have a standard Precision T76GTS right? Thats not a ball bearing turbo.
Old Jan 24, 2008 | 03:08 PM
  #27
That's what I have. Here I thought I has gotten the best model for my mostly street-driven car. Can I upgrade a turbo later to incorporate a ball-bearing setup?
Old Jan 24, 2008 | 03:23 PM
  #28
you could but honestly for what it will cost you, its probably not worth it. the ball bearing will decrease spool time by a few hundred rpms but nothing dramatic though for a street car this might be nice, the real advantage water cooling has is the reduction of coking the bearings due to oil temps being too high by keeping temps under the coking threshold
Old Jan 24, 2008 | 03:27 PM
  #29
RealQuick's Avatar
You have the most power T4 Precision/turbonetics turbo out there (ignoring the new turbos offered by Jose @ Forced Inductions). IMO, BB isnt worth the cost upgrade unless you get a deal on one.
Old Jan 25, 2008 | 11:55 PM
  #30
Thumbs up
Thanks guys, that made me feel better!
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
Jul 4, 2005 05:00 PM
GA93FORMULA
Jul 24, 2002 11:38 PM
