o-ringing the heads
Old Nov 16, 2003 | 10:58 AM
Fast S/C '94Z's Avatar
o-ringing the heads
I have blown 2 FELPRO 1074's head gaskets on my motor and was wondering about what is needed or if it can even be done on our lt1's. How much would a good machine shop charge if you have already done this? This is the ultimate solution to blown head gaskets, correct? Any help is apreciated.
Ray
Old Nov 16, 2003 | 05:07 PM
sleeperz28's Avatar
Search the topic. Check your tune a good set of studs will hold the heads down, ive been running 20psi with no problems for over 8,000 miles
Old Nov 16, 2003 | 07:47 PM
93formula's Avatar
try cometic gaskets, at www.cometic.com
how much psi were you pushing? are you using head studs?
Old Nov 19, 2003 | 05:14 AM
john35thss's Avatar
Don't o ring !!!!. I made that mistake, I have a coolant leaking mess. Race car ok, street car forget it. I've had the heads off twice. First time I assembled motor myself, it leaked even though I used copper spray and silicone. Second time took motor to engine builder and had them assemble, guess what its leaking again. So I have a short with 3000.00 in machining I can't run a regular (cometic) gasket on and now I have to put up with this bull untill I build another short
Victor Lamb
Aug 26, 2017 02:52 PM
Roadie
Feb 16, 2015 10:34 AM
NewsBot
Jan 29, 2015 07:10 PM
NewsBot
Dec 28, 2014 06:20 PM
