New Hand held wideband system
Old Feb 12, 2004 | 10:51 AM
MEAN LT1's Avatar
http://www.kennedysdynotune.com/
I think at the cost of the system it will sell pretty well. Im already looking at it to put to use on my car. I see this item win best new sema product. And I know if Kennedy's dyno Tune caries it I know its a good product.
Old Feb 12, 2004 | 11:56 AM
rskrause's Avatar
Moderator
Re: New Hand held wideband system
I think I at the cost of the system it will sell pretty well. Im already looking at it to put to use on my car. I seen this item win best new sema product. And I know if Kennedy's dyno Tune caries it I know its a good product.
I have one and it works well.
Rich Krause
Old Feb 12, 2004 | 01:30 PM
Wild1's Avatar
For tuning only... correct? Seems like the right way to go.
Old Feb 12, 2004 | 01:53 PM
rskrause's Avatar
Moderator
Right. It has a number of neat features. Notably, datalogging including to ability to log rpm and AFR and then download the data for display on a PC.
Rich Krause
Old Feb 12, 2004 | 02:20 PM
MEAN LT1's Avatar
Rich Krause
Question, as far as the cableing goes, do you just bring it in through the door opening?, or how does that portian work?.
Old Feb 12, 2004 | 08:24 PM
SC97TA's Avatar
Is there any one that is logging RPM?
How did you connect it to the LM-1 and the car?
Kris
Old Feb 12, 2004 | 10:52 PM
Highlander's Avatar
That is the lm1
you can check it out at
www.innovatemotorsports.com
I have one.. it works wonderfully.. the best is that you can tune at the street.. there is an exhaust clamp that works beautifully...
You can connect the LM1 to the RPM via the inductive pickup nad rpm converter...
My converter got damaged for some reason and they replaced ASAP at their cost.. I just shipped the old one back...
Great costumer support... the total package went for like 500 bucks with all needed accessories
350 for the lm1
99 for the rpm converter
20 for inductive pick up
75 for exhaust clamp + shipping...
of everything...
it logs rpm and a few nice things... you can connect it to the pcm and download all the data and also has a monitor program that lets you see real live as it is being logged...
with the rpm inductive you just tap into the spark wire and that is it
Old Feb 12, 2004 | 11:16 PM
SC97TA's Avatar
Is that the only way to receive the RPM signal...through an inductive clamp?
Or can you splice into a low voltage source such as the ignition control wire?
Kris
Old Feb 12, 2004 | 11:39 PM
Highlander's Avatar
Yes you can.. the rpm converter is an expander where you can log... MAP.. TPS... RPM.. up to 5 inputs w/o a problem... 12frames/s
Old Feb 13, 2004 | 10:57 AM
SC97TA's Avatar
Cool…I have been kinda reading up on the LM-1 and the RPM converter. Read some problems people have had logging RPM and getting noise in the signal. Seems they’re all grounding issues making sure your ground of the LM-1 and the tach ground are at the same potential. Just wanted conformation that someone with an LT1 has tapped off a low voltage RPM source with success and which wire it was (ignition control, injector wire…).
Don’t want to use the inductive clamp if I don’t have to…just makes a cleaner install IMO. Still will buy it to tune other vehicles.
Thanks for the info
Kris
Old Feb 13, 2004 | 11:52 AM
Highlander's Avatar
I do not wish to install it.. that is why I want to use the inductive clamp
Old Feb 26, 2004 | 03:13 PM
ryaskovic's Avatar
Highlander....what's the $75 exhaust clamp for? Will I need it if I have extra O2 bungs already in place?
Thanks,
Old Feb 26, 2004 | 03:26 PM
Highlander's Avatar
Exhaust clamp is MEGA CONVENIENT if you do not have the bung.... and if you dont have CATS
I suggest you buy them because its a handy tool
Old Feb 26, 2004 | 07:08 PM
ryaskovic's Avatar
Could you explain it a bit more? I've seen the website but I'm still not clear. I've already got the extra bungs. I don't have cats. What is it and what does it do for you?
Old Feb 26, 2004 | 07:11 PM
Highlander's Avatar
Its a clamp that you put in the exhasut tip and you isntall the sensor there... since you do not have to get under the car is very useful to install it and then remove itwhen you are done.
