New Hand held wideband system
http://www.kennedysdynotune.com/
I think at the cost of the system it will sell pretty well. Im already looking at it to put to use on my car. I see this item win best new sema product. And I know if Kennedy's dyno Tune caries it I know its a good product.
Re: New Hand held wideband system
I think I at the cost of the system it will sell pretty well. Im already looking at it to put to use on my car. I seen this item win best new sema product. And I know if Kennedy's dyno Tune caries it I know its a good product.
Rich Krause
Originally posted by Wild1
For tuning only... correct? Seems like the right way to go.
Rich Krause
Originally posted by rskrause
Right. It has a number of neat features. Notably, datalogging including to ability to log rpm and AFR and then download the data for display on a PC.
Rich Krause
Rich Krause
That is the lm1
you can check it out at
www.innovatemotorsports.com
I have one.. it works wonderfully.. the best is that you can tune at the street.. there is an exhaust clamp that works beautifully...
You can connect the LM1 to the RPM via the inductive pickup nad rpm converter...
My converter got damaged for some reason and they replaced ASAP at their cost.. I just shipped the old one back...
Great costumer support... the total package went for like 500 bucks with all needed accessories
350 for the lm1
99 for the rpm converter
20 for inductive pick up
75 for exhaust clamp + shipping...
of everything...
it logs rpm and a few nice things... you can connect it to the pcm and download all the data and also has a monitor program that lets you see real live as it is being logged...
with the rpm inductive you just tap into the spark wire and that is it
350 for the lm1
of everything...
Cool…I have been kinda reading up on the LM-1 and the RPM converter. Read some problems people have had logging RPM and getting noise in the signal. Seems they’re all grounding issues making sure your ground of the LM-1 and the tach ground are at the same potential. Just wanted conformation that someone with an LT1 has tapped off a low voltage RPM source with success and which wire it was (ignition control, injector wire…).
Don’t want to use the inductive clamp if I don’t have to…just makes a cleaner install IMO. Still will buy it to tune other vehicles.
Thanks for the info
Kris
Thanks for the info
Kris
