Need lt1 turbo headers
Old Nov 21, 2007 | 10:48 AM
c0rey's Avatar
Im looking to find a set of headers that will fit without the ac and the rad in the factory position. Got a mpt70. Was thinking maybe some block huggers? Need advice. Need to either find some headers or go with a log setup. Suggestions would be great.
Old Nov 24, 2007 | 12:30 PM
c0rey's Avatar
Im looking to flip these forward and delete the ac. I was wondering if anyone see any problems with getting them to fit? They look like they will clear the steering and everything in a lt1 camaro
Old Nov 24, 2007 | 01:47 PM
crazycat's Avatar
www.lt1boost.net
Old Nov 24, 2007 | 02:24 PM
Ok4thGen's Avatar
well c0rey the exhaust ports on ltx style heads are a D shape not a circle =/
Old Nov 24, 2007 | 03:14 PM
1982z28with18s's Avatar
I second www.lt1boost.net
Old Nov 24, 2007 | 09:56 PM
c0rey's Avatar
I know about realquik I just want to fab up my own kit.
And I think he uses regular sbc flanges on his kits.
Old Nov 25, 2007 | 09:47 AM
RealQuick's Avatar
Regular SBC flanges are fine... as long as the hole in the flnage is bigger than the port, your fine.
Those headers dont look bad... are they 1/4" flanges though? Kind of thin, but you technically could use them. Honestly, get a set of shorty headers specific for an LT1, run them in their normal location, merge them near the starter, have the single merged pipe run under the pass. side motor mount tot he front and then mount the turbo anywhere in front.
If you truly want a set of LT1 headers that clear everything when facing forward, the SLP dual cat headers will work.
Jon
Old Nov 25, 2007 | 10:28 AM
c0rey's Avatar
Those headers have 5/16 flanges and 1 5/8 primarys.
Old Dec 4, 2007 | 02:59 PM
c0rey's Avatar
Well those didn't fit. Time to build logs.
Old Dec 4, 2007 | 03:48 PM
RealQuick's Avatar
What part? Looks like the pass. side may come out and hit the inner fender?
Old Dec 4, 2007 | 04:02 PM
c0rey's Avatar
The drivers side cleared the steering but kind rubbed on the rag joint and dumped on the sway bar. Passenger side hit fenderwell.
Just gonna be easier to build something outta scratch.
LeftoverChinese
Jan 14, 2024 03:03 PM
Highlander
Jan 12, 2020 02:13 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
Roadie
Feb 16, 2015 10:34 AM
blac94Z
Jan 22, 2015 11:19 PM
