View Poll Results: which way to go
s80 turbo
66.67%
f1a or bigger procharger
33.33%
Voters: 6. You may not vote on this poll
need lots of help
Old Jul 6, 2008 | 11:45 PM
ssfbody96's Avatar
need lots of help
ok fellas this is my first post so i suppose it better be a good one. i have a 1996 camaro ss bone stock right now. i have been building a 383 forged bottom end with 8.5 cr. i was thinking on going with dart heads and a single plain intake setup. now the fun part as it has been debated soo many times. should i run a f1a procharger on this motor or a forced inductions s80 turbo? i know all about the turbos and what they are capable of but dont know jack about prochargers but was told a f1a was the biggest i could get. the goal for the car is to be a car i can drive on the street and take it to the track and bust out some 9 sec runs. the car is also a 6sp if that helps on what i should i do. like i said i know what kind of whp numbers i can expect outta a turbo so i guess what could i expect out of a f1a? and also is that the biggest i can go? thanks for the info and feedback as it is going to help me out a ton.
Old Jul 6, 2008 | 11:47 PM
reamo04's Avatar
i personally like turbos more. You seem to know more about turbo's than you do prochargers, so i would recommend that route as well.
Old Jul 7, 2008 | 06:18 AM
number1's Avatar
Stock to FI 383? That is a decent size step up.
I would say turbocharger only if you know what you're doing, otherwise superchargers are great.
Old Jul 7, 2008 | 03:20 PM
97FormulaWS-6's Avatar
I can tell you the 9's, combined with streetable, combined with the 6-sp = very very questionable.
With HP levels needed to run 9's, being streetable is a relative term. From what i've seen >100 octane is required; and the HP levels will destroy most (and all at some point ) T-56s.
Old Jul 7, 2008 | 03:33 PM
number1's Avatar
What is a S80 turbo? I thought that was a Volvo....
Old Jul 7, 2008 | 05:40 PM
Kevin Blown 95 TA's Avatar
It is going to be a bunch of money by the time you build your streetable 9 second car. It might be $25,000 to do it right and make it last.
Old Jul 7, 2008 | 07:05 PM
EASY $25K, and if you're smart add another large chunk to make it SAFE...
Old Jul 7, 2008 | 07:08 PM
FireChicken1995's Avatar
yea... im past that and the car isnt even running yet. turbo FTW
Old Jul 7, 2008 | 07:36 PM
ssfbody96's Avatar
this is the turbo jose at forced inductions recommened for a 383 to get it into the 9's
[URL="http://forcedinductions.com/productsborgwarner.htm"]
trust me fellas i know it is going to be prob. at least 30k to do this. i know for sure its not going to be cheap and ready to pay it. lol. i am tired of checking out ls1tech and seeing all these 9 sec ls1's i'm ready to sign up over there and put the lt1 on the map but i need to do it first. also i just really want a badass car from stock to 9 sec. i know is a dramatic change but i have driven and owned a 10 sec camaro so it shouldnt be anything i'm not use to. but i'm not going to sit here and say its going to run 9's you know what i mean. i am saying i want a 9sec ride and wanted to know what could most def get me there. thanks guys for the responses as i am seeing the turbo wins hands down. i am pretty confident with the right setup,tune and a really expensive tranny it should hold up pretty good you know tune it down for the street to drive some on the weekends then when i put r.gas in load a new tune and let it rip that would be the idea ticket. but whatever it takes i am determined to do it. projected start up date to get the project rolling is going to be dec/jan time a few months after i mark-up. but again thanks guys any other ideas be sure to throw them out there cause i got awhile to think this set-up through i want the best combo to run 9's i only plan building once hahaaha like we know thats going to happen.
Old Jul 7, 2008 | 07:41 PM
Full Roll Cage
Large Intercooler
Large Heads
Crazy Valvetrain
Large single or 70mm+ Twins
Aftermarket EMS (Fast/Megasquirt)
HUGE fuel system (at least dual pumps with large lines & Injectors)
TH400 or 4L80E upgraded tranny; or a couple t-56s so you can swap them out as they get rebuilt
Strange 12-bolt or S60 rearend
All aftermarket suspension (Rear at least including a chassis-mounted T/A
Lots of patience, $$, and know-how to fab everything.
Old Jul 8, 2008 | 06:26 AM
number1's Avatar
http://s95.photobucket.com/albums/l1...t=P1010464.flv
Car that won pump gas drags.
Rpm Hp Tq
5000 1124 1181
5500 1311 1252
6000 1451 1270
6500 1643 1328
7000 1723 1293
This car is a procharged 572 @18 pounds. I have some pictures of this car somewhere, it is awesome seeing it driving around. (Madison Hot Rod Power Tour '08)
2QUIK6
Sep 17, 2016 02:31 PM
gonzo275rltw
3rd Gen / L98 Engine Tech
Sep 7, 2015 04:46 PM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
Pwilson59
Sep 3, 2015 08:47 PM
