Need a good head gasket for 14 lbs
Re: Need a good head gasket for 14 lbs
I've had the cometics and studs for two years with no problems. Tuning is the biggest thing.. run lean or detonate and you'll blow out about anything you have.
[QUOTE=Lonnie Pavtis] The stock LT1 gasket is thicker & made of weaker material... do not use these. You should be fine with a 1074 & studs./QUOTE]
I just found out yesterday that i had the stock replacement head gasket on my car. I thought when we rebuilt it we used the 1074 but i was wrong.
I was losing compression into the water jackets on the #2,#8 cylinder and the #1 was starting to do the same thing.
What is the part# of the head studs?
Travis
Travis
Originally Posted by wicked_95z
I just called summit racing and ordered them. Dont remember the part number
Travis
Well what I was asking was for you to look on your invoice when you recieve them. It will have the part# on there, it should be one of the part#'s above.
Oh okay...well Ive got more bad news. I ordered mine a while back and they are already on the car and the invoice is gone. Sorry I wasnt very clear, I hadn't just ordered them. I simply told summit what I wanted when I placed the order
Thanks for the help anyways.
