Need forged dished type pistons for lt1?
Old Nov 22, 2007 | 12:30 PM
bym's Avatar
bym
Im planing on supercharging a lt1 engine going with a little higher boost than 7 psi, around 12/15 psi. I want to buy buy dished type pistons to lower compresion ratio up to 9.00:1 to prevent detonation. But i cant seem to find around, a specific brand or number for the lt1 engine with stock heads, crankshaft and rods. Please help on this im kinda rookie on this. the brand and part number would be apreciated or piston dimensions will work also..
thanks
Old Nov 22, 2007 | 04:07 PM
Eric@Victory Racing's Avatar
We carry a full line of products from JE, Wiesco, SRP, Ross, and Diamond. I will send you a PM with some information.
Old Nov 22, 2007 | 04:42 PM
Boosted_Z28's Avatar
The standard 1st gen s.b. Chevy and the LT-1 use the same internal rotating assembly parts.
Try going to: http://www.jepistons.com/cat/je/auto...y_23_inv.shtml
This will list a variety of forced induction pistons. Most likely, you will find something that meets your needs.
Old Nov 22, 2007 | 09:00 PM
97WS6Pilot's Avatar
Sealed Power Powerforged Speed Pro L2441F30 or L2441F. These are the D shaped that Lingenfelter mentions in his book.
http://www.jegs.com/webapp/wcs/store...10002_26084_-1
Old Nov 23, 2007 | 11:24 AM
BIGCATPOWER's Avatar
je pistons makes a real good piston. we are runing 22psi on a set with no failures. ps you need to give a little more info on you motor. ie is it stock.
Old Nov 23, 2007 | 09:18 PM
DirtyDaveW's Avatar
Eric at Victory set me up with my set for my turbo motor.
http://www.taekwondoplus.org/z28/Tur...rbopistons.htm
Great customer service, great follow thru and pricing.
LeftoverChinese
Jan 14, 2024 03:03 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
Noer
Feb 28, 2015 11:29 AM
Queens94z28
Nov 20, 2014 06:03 PM
