My turbo progess
Old Feb 29, 2008 | 01:13 PM
  #46
LT1-TA's Avatar
Man it sucks the pictures dont come up on the computers at work =(
Old Mar 1, 2008 | 02:53 PM
  #47
reamo04's Avatar
well, i thought i could go today wtihout working on it....i lied to myself
just needa get the merge made, which i figured out how i will do it, and then get some flex pipes ordered, and it should be getting ready to go.
Old Mar 3, 2008 | 04:50 PM
  #48
reamo04's Avatar
well guys, flex pipes (2) are ordered and on their way. Wastegate spring is on its way.
Look for a COMPLETE hotside this week
Old Mar 3, 2008 | 05:13 PM
  #49
IROCThisZ28ForLife's Avatar
:claps hands: yay
Old Mar 3, 2008 | 08:27 PM
  #50
reamo04's Avatar
well guys, after looking at it and thinking about it, i have to redo my bracket. Because, i have it bolted to the motor AND the frame....so, i have to make it one or the other. Frame is looking like it will be easier since i have that perfect little sway bar mount to use, and a set of flex pipes....
Old Mar 4, 2008 | 11:31 AM
  #51
jay_rich's Avatar
Where are you gonna put the O2 sensors?
I just got my C4 manifolds and they have a spot in the middle of the middle ports... I will snap a pic when my batteries charge :P
Jay
Old Mar 4, 2008 | 12:26 PM
  #52
reamo04's Avatar
going to put them right after the headers, and my wideband in the downpipe
Old Mar 4, 2008 | 01:15 PM
  #53
jay_rich's Avatar
good call on the placement....But arnt widebands on turbo cars suppose to be 36 inches downstream? I know my AEM is in the Y pipe bc i planed on spraying my car.
Jay
Old Mar 4, 2008 | 02:20 PM
  #54
jammer94's Avatar
you know what i noticed the older vette motors like the 1st TPI motors dont come with cast manifolds they come made like a block hugger header, the manifold you posted above looks to be off a newer vette but they are CAST for sure. and on the placement of the o2 in the middle of the ports probably wouldnt work right as they need to be at closest in the collectors.
and for my wideband off the FAST i have them about 20-22 inches away.
Old Mar 4, 2008 | 04:07 PM
  #55
reamo04's Avatar
well guys, got the driver side completely welded up. I need to get some slimmer fans though, because my turbo hits the fan a little. I also need to get my oil cooler deleted this week so i can get the welder back to my friend haha.
Old Mar 4, 2008 | 08:50 PM
  #56
jammer94's Avatar
check your other post as i threw you some info...
Old Mar 6, 2008 | 05:56 PM
  #57
reamo04's Avatar
well guys, lookie here, MORE progress
not bad considering i had a doctors appointment today, and it was quite a PITA to get everything to fit JUST right.
so, all thats left, is getting the driver side into the merge pipe, shouldnt be too bad, ive made it this far afterall haha.
Old Mar 6, 2008 | 10:29 PM
  #58
reamo04's Avatar
well guys...(esp jon), i think my turbo may be a little on the low side....and i am pricing pumps....anybody have any links?
Old Mar 7, 2008 | 10:40 AM
  #59
RealQuick's Avatar
I have seen kits where drain lines are horizontal and they seem to still drain. As long as you are better than horizontal (parallel to the ground), then you should be fine.
Old Mar 7, 2008 | 11:13 AM
  #60
reamo04's Avatar
alright. I mean, i havent tapped my pan yet or ran it, but looking at it i was like...hrm.....it almost might be too low
