Motor oil question for you boosted guys...
Old Mar 18, 2007 | 03:02 PM
roguedriver's Avatar
So what kind of motor oil are you guys using in your boosted cars? Assuming you engine was put together with looser tolerences due to boost, N2O or both, what weight oil are you using? Also, using conventional, synthetic or a diesel oil like Mobil Delvac, Cheveron Delo ect. I've heard of guys going the diesel oil route, which at first, i've never really heard of, but after doing some reading, it seems a lot of guys go that route, and after reading a bottle of Delvac for my Duramax, it's meets requirements for gas engines also, so it would seem to be an option also. Just wondering what benifits a diesel oil would have over others for applications like ours and if it's better to use a heavier weight in a boosted/N2O setup. Thanks.
Ken R.
Old Mar 19, 2007 | 09:03 PM
CALL911's Avatar
I don't know about the deisel oil as I have never heard of anyone running it. Personally, when my motor was built, it was built with larger than stock clearences on everything, which better supports a thicker oil. Some people give me this face when I tell them I run 20W-50 but that is exactly what my motor shop reccomended for my motor. It seems to run great so far. I know I could probably gain a HP or two by swapping to a synthetic thinner oil, but having my clearances that I do that thinner oil won't do the same job my thick oil does. I don't really mind this because the oil is a good 75% cheeper than going with the Royal Purple synthetic stuff I was running before the engine rebuild.
Old Mar 20, 2007 | 09:09 PM
oil pan 4's Avatar
I all ways liked Mobil 1 10w-40 weight MX4T (renamed "Racing 4T).
It has a unreal amount of anti ware addtives, VOA's pop about 1800ppm of Zn and about 1500ppm of P.
That is great for the engine but can cause ash build up.
The New CJ-4 plus diesel engine oils have plenty of anti ware and are reduced ash for the new 2007 diesels.
I use Synthetic Shell Rotella T 5w-40 weight.
Old Mar 21, 2007 | 11:14 PM
OBE1 95Z28's Avatar
More than you'll ever want to know about oil: http://www.bobtheoilguy.com/
Old Mar 22, 2007 | 12:45 AM
97WS6Pilot's Avatar
Castol Syntec Blend 5W30.
Old Mar 22, 2007 | 01:41 AM
JWS6's Avatar
The green castrol got me really excited, i found some here in Vegas and tried it out last summer. Unfortunately, I too have larger than stock clearances and wasnt happy with the oil pressure. I'm running 15/50 Mobile 1 right now(the 1 gallon jug from walmart) but would still like a bit more pressure.
Old Mar 22, 2007 | 06:58 AM
cjmatt's Avatar
ive been getting good pressure with regular mobil 10w40, but ill be switching to synthetic after im totally broken in
Old Mar 22, 2007 | 10:04 AM
joe-96z1le's Avatar
Castrol 10W-40 conventional until I get about 1500+ miles on the motor. Then switch to synthetic oil, probably Royal Purple.
HectorM52
Jul 30, 2017 11:46 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
Donwest22
Parts Wanted
Dec 18, 2014 11:10 AM
