Mono blade and FI
Re: Mono blade and FI
Originally Posted by Alvin@pcmforless.com
The throttle bodys have a cheap *** spring that won't let them shut.
Pretty dissappointing when you consider how much they cost.
Well, i've got the biggest baddest spring advanced auto cells as a carb return spring and it still hangs open occassionally.
Forgive me for expecting a throttle body that expensive to close by itself.. I was pretty irratated at that whole ordeal. When I got it it wasn't even strong enough to close at a idle giving the car small blips in throttle. It would hang open with the vaccum this cam pulls and the air (not boost) that the blower makes.
They could have solved this easily by making the shaft a bit off center.
Well, I got it to work halfway decent with an aux return spring but to me that is just BS. I mean this is a clean car underneath the hood and the throttle body is otherwize really clean looking but not with a aux spring hooked up.
I wouldn't buy another.. Put it that way.
ASM PRODUCTS=
I mean come on now they already know that theres a porblem with there spring and they dont fix the design,,come on asm step your game up
Originally Posted by SiDeWaYZz28
ASM PRODUCTS=
ok well yea i did go alittle to far but now they need to fix the problem with the mono because here in the near future id like to convert to that style of t/b
hosspwr94
Mar 5, 2003 11:49 AM
MarcPike94B4C
West South Central
Jul 10, 2002 04:21 PM
