methanol pump location?????
Old Jan 7, 2012 | 07:38 PM
95maroboi's Avatar
Where did you guys put your pump?there is no room for anything under the hood of this car.
Old Jan 8, 2012 | 06:29 PM
95maroboi's Avatar
Re: methanol pump location?????
anybody??
Old Jan 8, 2012 | 06:46 PM
BlackbirdWS6's Avatar
Lot of guys will mount the pump somewhere behind the front bumper. I run the twin intercoolers so I had no room for the pump there. I ended up putting it under the washer fluid tank. Well protected and no issues. I may move it to get a little more airflow to the radiator. I use my washer fluid tank as the meth tank.
Old Jan 8, 2012 | 07:30 PM
Kevin Blown 95 TA's Avatar
I stuck mine under the area where the fuse box/air box is - not in the engine compartment behind the headlight, but underneath there mounted upside down. Then I used the windshield wiper resevoir for the meth/water
Old Jan 9, 2012 | 01:06 AM
97WS6SCharged's Avatar
I have an old SMC kit with the pump mounted inside a fuel cell/jug which is mounted in the hatch. I'll try to post a pic later.
Old Jan 12, 2012 | 03:55 PM
95maroboi's Avatar
thanks kevin blown 95 that spot worked perfectly!
Old Jan 29, 2012 | 11:01 AM
blue's Avatar
I guess you got your answer but I also put mine in about that location--behind the DS headlight. Put the intercooler radiator in front of the stock radiator. Very tight fit on the pump with a custom made bracket but it works.
HectorM52
Jun 23, 2016 08:42 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
95maroboi
Jun 7, 2015 12:18 PM
Chet1185
Parts Wanted
Mar 15, 2015 04:29 PM
