Maxing out MAF sensor
Old Mar 18, 2005 | 10:19 PM
  #61
ss#1230's Avatar
Re: Maxing out MAF sensor
Originally Posted by maximumvelocity
Once again I will ask: Anyone ever hear or know of the "Mass Airflow Massager" part number MA001I-1 from procharger for 1996-1997 LT1's w/obd2? I am not familiar with it, all i know is that it comes with a supercharger kit and is somehow related to the maf.
yes, i know basically nothing about tuning. id like to get a tuner program but i cant afford what id need for my obdII car right now so it will probably be a while before i start my own tuning.
i tried to get some info on the maf massager here but i got about as much info as you apparently have.
i didnt expect to have a problem with my maf when i put my vortech(standard 6psi kit) on, but i did. when my maf maxed out the car cut out, started shuttering and barely wanted to run. my brother in law who is a gm mechanic scanned it and it coded for maf error and excess airflow.
i ran it for a while without the maf and it ran okay, just smelled pretty rich. once i got the MAF massager from procharger i got the car dyno'd then had madz28.com tune it off the dyno/AF graph. i runs good, and on the dyno it didnt jump around at all as far as the AF goes. just a little rich still, so ion leaned it out some.
im not sure what the massager does, but it seems to work well. it cost $195 otd.
Old Mar 18, 2005 | 10:21 PM
  #62
Highlander's Avatar
Bore The Maf To Heaven
Old Mar 18, 2005 | 11:42 PM
  #63
maximumvelocity's Avatar
ss#1230, do you have a pic of what it looks like? is it end pieces to the maf, or does it connect between the maf and the computer? Thanks for the info.
Old Mar 19, 2005 | 12:40 AM
  #64
Schurters LT1's Avatar
When porting the MAF sensor out, are you just editing the MAF tables at idle and that is it? ie: 0-1500rpm is where you would adjust...
Old Mar 19, 2005 | 11:59 AM
  #65
ss#1230's Avatar
it plugs between the maf and the harness. its a box with a long extension wire on it so that you can locate it in the same area as the air filter is located(infront of the LF wheel). but since thats where my maf is i just coiled it up and tywraped it to my aftercooler hoselines.
ill take a pic of it and email it to you when i get a chance.
are you having problems with your maf maxing?
jeremy
Old Mar 23, 2005 | 07:39 PM
  #66
ss#1230's Avatar
MAXVELOCITY......emailed you pics of the signal massager....
Old Mar 23, 2005 | 07:49 PM
  #67
Seal's Avatar
i have a problem with this...
as soon as i start boosting, the computer will ignore any table (PE or afr vs coolant temp) and will just dump fuel, making me run at 9-10s AFR... i have edited the tables to max - to take out fuel, but nothing happens.... i had to edit my MAF tables to get it to work...
Old Mar 23, 2005 | 07:56 PM
  #68
SMOKNZ's Avatar
What are your injector pulsewidths when this happens?
Old Mar 23, 2005 | 08:00 PM
  #69
Seal's Avatar
i'd have to check, i dont have any runs with it....
i'd have the put the old tune back on and see... very lazy to do that lol
what i did works fine... i run off open loop, and as soon as i boost (when the MAP would read higher then 103kpa) i go REAL rich... (again, dont remember the inj pw) so i just tuned the maf from 150 gps and on to 20% less....
seems to work well.... i get real good cruise afr (anywhere from 13s-14s) and when i floor it right as the gps gets to 150 the car kinda jerks for a split second (AFR hits 16 really quick) and then it starts to pull real hard at 11.7-12.3
andrewcapps82
May 19, 2015 10:11 PM
Dzmaro
May 7, 2015 09:33 AM
3TAS4ME
Apr 15, 2015 02:24 PM
pete53
Dec 9, 2014 07:31 AM
