Maxing out MAF sensor
Old Dec 14, 2004 | 10:29 AM
  #31
maximumvelocity's Avatar
Re: Maxing out MAF sensor
Originally Posted by SMOKNZ
From what I have herd, and not generally concidered to be true because I haven't taken apart the computer and looked, the circuit consists of 2 256 bit registers giving a theoretical max of 512 gps. I have had mine at 510, and I have logged this reading several times when the MAF is maxed. It occures at the same time as the stock 471gps, however like I said before when the MAF is maxed it adds a little more fuel to the mix as the PCM thinks it is locked at 510 gps of air and not 471. still doesn't get around the fact that tuning still needs to be done in the PE table per RPM to get things right.
Wait, so you are running OBD2 and the MAF is not cutting your fuel in half when it's maxed out at the upper RPMS? Is it or is it not acting like "speed density" all the way up?
Old Dec 14, 2004 | 01:36 PM
  #32
SMOKNZ's Avatar
No it's not cutting it, but I run a OBD1 conversion in my 97.
Old Dec 27, 2004 | 11:00 PM
  #33
Anyone have any ideas on solving the maxed maf on the OBD2? Is there perhaps another maf out there that maxes much higher that will work? ZO6 MAF? Not lookin to spend the Big $$$ on a pro-m MAF just yet. Tunercat just came out with their new OBD2 software. Perhaps there is something in there wich could help? Anyone with anything?
Old Dec 28, 2004 | 12:28 PM
  #34
NJLT1SS's Avatar
Speaking of mass airflow sensors, has anyone ever heard or used this one: Pro M Mass Air Meter I saw it on Ebay, but dont know anything about it. Can anyone shed some light on it?
Nick
Old Dec 28, 2004 | 01:58 PM
  #35
SMOKNZ's Avatar
Looks like it is stock MAF electronics with different ends, nothing new, and won't help anything.
Old Dec 29, 2004 | 12:50 PM
  #36
TriPinTaZ's Avatar
I increased the GPS reading in the maximum part of MAF table 4 to 510, but it still doesn't change what frequency output of the MAF it maxes out on. Just adds a little more fuel up to the point where it maxes. I haven't checked out the new tunercat file either, so I'll see if anything has changed.
in LT1 Edit 2.2 you can change the MAFs frequency fail point. This is what I was talkingabout changing. Changing the MAF tables themselves isnt going to do anything to fix the issue.
Old Dec 29, 2004 | 02:00 PM
  #37
SMOKNZ's Avatar
IS Tunercat capable of this, and How high can you adjust the high MAF fail freq?
Old Dec 30, 2004 | 03:13 PM
  #38
Highlander's Avatar
OBDi or OBDii in LT1edit?
Old Jan 12, 2005 | 06:41 AM
  #39
Anyone ever hear of "Mass Airflow Massager" part number MA001I-1 from procharger for 1996-1997 LT1's w/obd2? could this solve the maxing out issue with boost applications???
Old Jan 20, 2005 | 07:22 PM
  #40
Will an aftermarket maf solve the problem for OBD2 then?
Old Jan 21, 2005 | 01:00 AM
  #41
TriPinTaZ's Avatar
as far as i know the new tunercat will adjust hte max maf fail point on OBD1 cars and LT1_edit can change on both OBD1 and ODB2
Old Jan 21, 2005 | 04:50 AM
  #42
SMOKNZ's Avatar
I have the latest edition of Tunercat and cannot find this, where do you adjust it?
Old Mar 17, 2005 | 10:06 AM
  #43
Geoff Chadwick's Avatar
Drag this back from the dead for some more light on the subject...
Old Mar 17, 2005 | 10:56 AM
  #44
RealQuick's Avatar
Good idea. How is the car coming?
Old Mar 17, 2005 | 12:59 PM
  #45
Very good actually, hence my desire to get this answered.
Only "major" parts I have left to buy are the guages, the ignition system, and the leather door panel skins (doh!). But the ignition system will be determined by how the ECU will be tuned - for example do I get a setup that has built in boost retard, or do I try to leave that to the ECU? Once I know if this was taken care of, I can decide what components I want and order them.
Plan is it will be done by April 4th unless the ignition system is exotic enough to have a longer lead time.
