MAF High Fail Limit on 96/97
Ok, that's the highest number you can set the failure high freq limit to. But the MAF calibration table is still limited to 11216Hz; how will the PCM know what mass of air correlates with any frequency greater than that? It won't fix the lean condition, just keep the SES light from turning on.
Right, that's what I said before... just making sure we agree that upping the MAF failure limit won't fix the lean problem.
Until I have the car in front of me where I can make a change, then try it, then make another chance, then try it again, I don't know. I upped the limit and disabled the P0103 code. I'm helping someone in another town about 100 miles away that got a mail order tune from another shop with his STS kit. If the changes I made to his PCM make it driveable at all at WOT, he's going to bring me the car to dyno tune it. Right now, he just sent me his PCM and I sent it back.
I've got an STS kit on mine, but haven't had much of a chance to tune due to weather... and the fact that I'd been running it w/o MAF in SD mode. Hopefully I'll clean the oil out of the intake and be able to run a MAF system soon though.
MAF high freq threshhold maximum @ 65K+. The MAF cal high point is @ 512 grams/ sec. 512 g/sec flow is much less the 65K. It appears the this is a high limit set in the PCM code. Stock high freq setting was 10,700, and, it sure did set a PCM with that value. I run an ATI D1 with a 7 5/8 -> 3.4 pulley setup, and, have not found a PCM error with this maximum setting and reving to 6.8K.
I do know that I prefer the use of the MAF in closed loop mode to control AFR @ low speeds. Better drivability and throttle response.
I have not investigated disable of the MAF high freq error trigger. Also, if this error check is disabled, will the PCM auto default to speed density mode? I cannot comment.
Accel, FAST, Bigstuff3 are very tempting.
He's maxing out the MAF with his STS kit? Is it the basic 5psi kit on a stockish engine?
carguyshu
Jan 22, 2017 11:19 AM
May 1, 2015 01:14 PM
Jan 23, 2015 01:13 PM
