LT1 Twin Turbo Kit For Sale
Decided to go a different route and sell this kit. This is a complete kit. Less then 150miles on this kit since install. Kit is in perfect condition. Tubing has just been powder coated and intake tube has been chromed plus the headers were re-coated with a chrome finish 2000 degree coating. I also have a scavange pump with all the braided hoses and fittings that did not come with the kit that I purchased from Precision Turbo. That cost over 700 in parts. I Have pics available. Kit sells for $7000 without the scavange pump and custom chrome and powder coating and takes 2months to get . I am asking $4500 obo.
· dual Garret GT28 dual ball bearing turbos
· Tial 50mm Billet blow off valve
· 42lb Bosch injectors
· 24” long, 3” thick aluminum intercooler
· 2.25” intercooler tubing
· Custom headers with ½” flanges and 1-5/8” primaries
· 2.5” downpipes
· 3” main/ 2.5” secondary y-pipe that connects to factory style cat-back exhaust system with ball socket flanges
· 2000 deg coating on all hot parts
· Silicone hose at all intercooler connections
· Aircraft grade Stainless hose clamps
· Grade 8 hardware
· 2.5” downpipes
· Grade 8 hardware
Why did you decide to go a different route after 150 miles?
Who made this kit? How much boost is it capable of? How is spark plug access? Does it require the subframe to be dropped for installation?
I am wanting to go turbo, but I was planning on doing it this time next year. Let me see some pics at JWBerk@adelphia.net.
Were those 28's are a little small for what you were trying to do? Especially on a 383, you are going to need a turbo that has it's peak efficiency in the 40 lbs/min range.
I bet the kit will be good to around 650-700 hp though, probably a perfect kit for a street 355!
Bill
Bill
Yes this is the Turbolocity kit.
I decided to sell it because the car was going to be a show car and not driven all that often but after working on it over the last year or so I decided to take it to the next level and go for more HP. It does not require a sub-frame drop out to be installed but it does make it easier to work on without it in your way.
Dec 4, 2014 11:56 AM
LT1runner
33
Jul 24, 2002 01:19 PM
ced8
Jun 24, 2002 11:11 AM
