LT1 turbo setup
Old Sep 7, 2007 | 11:42 AM
RealQuick's Avatar
LT1 turbo setup
Here are some pics of a log manifold setup i am making for someone. He will be running a forged shortblock with stock heads/cam for now and TH400 combo. Here are some specs and progress pics:
1.75" primaries
2.5" pas. manifold with 2.5" crossover
44mm Tial style wastegate
3" main log
3" DP
Mild steel mig welded
Old Sep 7, 2007 | 01:38 PM
jsetzer's Avatar
Looking good. I tried to get a set of shorties to fit on my setup and finally got sick of it, went with a log style setup. Seemed much easier that way and I doubt I will lose any power, turbos are too small either way.
Old Sep 7, 2007 | 01:40 PM
RealQuick's Avatar
Thanks dude. So are you running twin turbos or single? If you are running twins, then the logs wont slow you down.
Old Sep 7, 2007 | 02:02 PM
FireChicken1995's Avatar
hummmm looks familure......
Old Sep 7, 2007 | 02:16 PM
jsetzer's Avatar
Twins
Old Sep 7, 2007 | 02:30 PM
RealQuick's Avatar
slow poke... hurry up.
Old Sep 7, 2007 | 07:58 PM
engineermike's Avatar
Realquick, I think you need to try and fit a 3.5" downpipe and let me know how it turns out.
Old Sep 7, 2007 | 08:24 PM
RealQuick's Avatar
Mike, with the stock k-member on the mockup, there is no way it would fit IMO. Now, I have a tubular k in my car and took some measurements... looks like a 4" would fit
Old Sep 7, 2007 | 08:28 PM
Looks like fitting it past the steering turnbuckle would be my first issue, then fitting it between the crossover pipe and the frame rail is the second. And that's on a 3.5". . .
Mike
Old Sep 7, 2007 | 09:14 PM
RealQuick's Avatar
Mike
Stock or aftermarket K?
Old Sep 7, 2007 | 09:40 PM
BMR aftermarket.
Old Sep 7, 2007 | 11:15 PM
only like 4 months man and il be home.... should have the car up by he beginning of march unless i chance my MOS (job) to blackhawk mechanic, il find out on the 13th.
Old Sep 8, 2007 | 11:23 AM
Chrisbequick's Avatar
Mine fits with the downpipe passing through the same area. Mine has a tubular K-member, though.
-Chris
Old Sep 8, 2007 | 11:26 AM
96TurboTA's Avatar
Do you think a 3.5" would fit through there if you ovalized it?
Old Sep 8, 2007 | 01:58 PM
RealQuick's Avatar
not sure...
