LT1 turbo project
Old Aug 2, 2009 | 11:42 AM
Quick Impala's Avatar
LT1 turbo project
I have done alot of searching, but some questions still remain. I want to install a single turbo on my LT1, stock for now. I will build a second 355 later with lower compression and forged internals. Here's the questions i have:
1) I have read the T70/.96 AR should be a good match for my car. I want to run 5-6 psi now, then turn it up to 10-12psi once the motor is built. Is this turbo going to do the job now then later as boost is increased? Or is it going to hold me back later?
2) Build the crossover pipe. Will 2.25" be sufficient from each header to the merge at the T4 flange be enough? Or should it be 2.50"?
3) Wastegate. Will a 38mm work if it is tapped in right at the collector before entering the turbo or should it be a larger wastegate?
4) I have read that the standard SBC header flange will work on the D-port head. Is this true? i'm planning on running 1 5/8" primaries into the header collector.
I'm very capable of fabricating this system, but my knowledge of v-8 turbos isn't that great. I'm moving over from the turbo 4 world, so this a bit new to me.
Old Aug 2, 2009 | 10:17 PM
MikeGyver's Avatar
1) look at the compressor map
2) sufficient for what? it certainly won't Not work
3) yes
4) LT1 flanges on ebay
Old Aug 3, 2009 | 05:32 AM
Well thanks for the help..
Old Aug 3, 2009 | 10:24 AM
RealQuick's Avatar
[QUOTE=Quick Impala;6059846]I have done alot of searching, but some questions still remain. I want to install a single turbo on my LT1, stock for now. I will build a second 355 later with lower compression and forged internals. Here's the questions i have:
QUOTE]
1. 70mm is fine
2. 2.5" minimum IMO
3. Go with a 40mm+ gate if you want 5-6psi without boost creep (be sure to pick a gate that offers that low of a spring)
4. SBC flange is fine on a D-port head as long as the flange doesn't hang over the port opening.
Old Aug 3, 2009 | 11:37 AM
jsetzer's Avatar
1. It will, but what are your power goals? 10psi on a low compression motor from a t70 will not make the same power as a different turbo at 10psi. I run my t70 in the upper teens psi wise.
2. 2.5" - Its going to be restrictive anyways
3. Toughie - For low boos you need one thats big enough for to vent all the extra. For high boost your waste gate can be too big. Mine is like a 70-72mm and when it finally opens it drops too much.
4. Will work, but I had bad luck with getting them to seal. LT1 D ports on ebay for cheap.
Old Aug 3, 2009 | 12:16 PM
Thanks alot for the helpful replies. I was thinking the 38mm wastegate may be a bit small since i plan on a low boost setting to start. Looks as though my original thoughts seem to be more or less correct. Now to start fabbing...
Old Aug 6, 2009 | 07:33 AM
DirtyDaveW's Avatar
What criteria are you specifying on Ebay to find those flanges? I tried everything I could think of but couldn't find any. I tried "LT1 D Flange", "LT1 Flange", "LT1 Engine", "LT1 Turbo", etc and never found them.
Old Aug 6, 2009 | 01:23 PM
RealQuick's Avatar
Email someone at www.clearimageautomotive.com as they are the ones that i bought my EBay D port flanges off of.
Old Aug 6, 2009 | 02:03 PM
jsetzer's Avatar
Ditto
Old Aug 20, 2009 | 04:55 AM
Does anyone know if there are dimensions on Master Power turbos available? I was wanting to compare physical sizes between the MPT70 and MPT76. Are they pysically the the same size as Turbonetics T-series turbos?
LeftoverChinese
Jan 14, 2024 03:03 PM
Roadie
Feb 16, 2015 10:34 AM
blac94Z
Jan 22, 2015 11:19 PM
cmdeshon
Dec 12, 2014 10:51 PM
