LT1 turbo drain to oil pan...
Old Apr 7, 2014 | 12:26 PM
BLWNLT1's Avatar
I have a kevco lt1 oil pan for my LT1 which is the same as a canton oil pan. My question is can I drill and weld on the top on the extentions of the oil pan for a turbo oil return line?
Old Apr 10, 2014 | 12:56 AM
97WS6SCharged's Avatar
Re: LT1 turbo drain to oil pan...
You can put an oil drain on top of the kick outs. The canton 242t has one on the passenger side. Keep in mind that you're going to need a downward slope for the drain and running it back there you will have quite a few obstructions in the way.
Old Jun 3, 2014 | 04:39 PM
97SS0594's Avatar
Anyone happen to know the size of the dip stick provision threads on the canton? I'm planning on using that for my drain...
Old Jun 3, 2014 | 07:38 PM
Jasonz28camaro's Avatar
I did that on my moroso pan and I'm pretty sure the kickouts are below the oil level line so you will need a pump I think. Gravity fed will not circulate too good if im correct. I ended up planning on tapping at the top of the pan above the oil level line.
LeftoverChinese
Jan 14, 2024 03:03 PM
DirtyDaveW
Dec 1, 2016 05:37 PM
blac94Z
Jan 22, 2015 11:19 PM
Sandersen511
Jan 13, 2015 03:49 PM
Jul 4, 2005 05:00 PM
