lt1 intercooler piping ???
Old Mar 18, 2009 | 01:13 PM
bayboi1600's Avatar
im running a single intercooler set up for my lt1 camaro i looked on ebay for piping kits and its alot of them on there im trying to find out exactly what kit i can use without having to modify the piping ive sent out a few pm's to people who stated they got there piping from ebay but i havent received any responses i have the procharger and the intercooler now i need piping
HELP ME PLEASE
Old Mar 18, 2009 | 01:26 PM
reamo04's Avatar
no matter what, these cars are not designed for intercoolers.
you will have to knotch out the bumper support
you WILL have to modify some of the aluminum pipes, or get really creative.
look for intercoolers for 240s, supras, skylines, etc.
http://cgi.ebay.com/ebaymotors/CXRac...1%7C240%3A1318
that is just the intercooler though, and you would have to order ALL of your piping
that appears to be the kit that I used for my car
Old Mar 18, 2009 | 01:46 PM
bayboi1600's Avatar
will this kit work MINUS the intercooler
http://cgi.ebay.com/ebaymotors/INTER...Q5fAccessories
Old Mar 18, 2009 | 04:20 PM
jsetzer's Avatar
Its 2.5" - it would but I would go 3" at least. Bigger if you are making serious power.
There won't be a direct fit kit out there - you will have to do some cutting. If you can't / don't weld you can use pre bent stuff and lots of couplers, but that will cost more and have more points for stuff to come apart.
Old Mar 18, 2009 | 09:24 PM
1996camaroSSclone's Avatar
-------> http://www.ls1tech.com/forums/forced...er-piping.html
Old Mar 19, 2009 | 12:11 PM
bayboi1600's Avatar
ok i started a thread on ls1tech also and ????
Old Mar 19, 2009 | 02:34 PM
It was good info. Either way there will be some cutting and welding.
Old Mar 26, 2009 | 11:32 PM
bayboi1600's Avatar
i need some piping bad
Old Mar 27, 2009 | 06:38 PM
mzgp5x's Avatar
I use a Spearco (25x3x12 core dimensions) IC. Mounted under, behind the rad with a low air deflector. Not a front mount bumper IC. Not conventional @ all with the masses, but, very good air flow thru the core with a large air duct. I also moved the rad forward and that helped alot with the air flow. I do question the air flow thru a front mount IC with a rad behind it. Also, the added weight on the front bumper can further bias more weight up front. OK for a drag car. Hard pipe air ducting is fairly easy to fab with a Miller MIG welder and a good saw. 97ss 383 D1 M6. B.
Old Mar 29, 2009 | 10:59 PM
DirtyDaveW's Avatar
I just went to ebay and purchased a piping kit. I actually had piping left over but it is entirely dependent on how you decide to route the setup. You'll need some additional couplers like Transitions to go from your up pipe to your turbo/supercharger, MAF and throttle body. Be sure to get access to or purchase a bead roller for those ends of the piping that you cut. If there's no bead for the couplers to grip upon, you'll find the pipes pop apart under boost with infuriating regularity.
http://www.taekwondoplus.org/z28/Tur...boColdSide.htm
Old Mar 30, 2009 | 05:55 PM
bayboi1600's Avatar
i purchased a kit off ebay im waiting for it to come in so i will post pics of the install from beginning to end thanks alot
onefastgta
Mar 19, 2015 10:10 AM
TYLER94Z28
Dec 3, 2014 07:05 AM
Burn_Out
Aug 18, 2002 08:49 AM
