LS1 Oil Feed
Old Aug 28, 2003 | 03:48 PM
racr4jc's Avatar
LS1 Oil Feed
Hey, where on the block can you tap into the LS1 engine's oil supply for turbo/supercharger?
Old Aug 31, 2003 | 01:48 PM
Secret Formula's Avatar
I want to know too, but LT1. Somewhere near the oil pump or filter?
Old Aug 31, 2003 | 02:34 PM
MIGHTYMOUSE's Avatar
ls1: there is a port right above the oil filter, take it off and drill through it.
Old Sep 2, 2003 | 03:23 AM
racr4jc's Avatar
so its in the same location as an LT1 block, right above the oil filter? So I remove the plug, but then I have to drill it out as well?
Old Sep 2, 2003 | 07:20 AM
i have no idea where it is on an lt1, i answered the question for ls1's.
Old Sep 2, 2003 | 02:11 PM
racr4jc's Avatar
thanks. but is it neccessary to drill the block or is it just a hole covered with a plug?
Old Sep 2, 2003 | 05:26 PM
get up under there and take a look at it.. its a fitting that is removable with 2 10mm bolts. from there you need to drill it out to the appropriate size based on the system and thread it for a 1/8"npt fitting.
rideordie
Nov 5, 2019 04:52 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
captcorvette
Mar 7, 2015 12:37 PM
ChrisFrez
Nov 23, 2014 10:33 AM
