low oil pressure after s/c install
Old May 2, 2003 | 07:28 AM
MEAN LT1's Avatar
Well, we compleated the supercharger install last night around 12:30am. It started right up and we made sure that there werent any leaks. We found a small coolant leak but it was ok. What did bother me was the fact that we werent seeing a nice stream of oil coming down the oil return line from the s/c back down to the oil pan. We did see some but not steady stream. Also after driving it for 30 minutes last night, I noticed my oil pressure was a bit on the low side. Usually at idle I get about 18-20psi of oil pressure and going about I get about 40 maybee a little less. Well when coming home last night I noticed while at a stop that I was a little belowe 20psi and when the light turned green and gave it some gas I noticed as I accelerated(sp) oil pressure didnt want to go up above 20psi. At 50 mph I was still at 20psi or a little above. I dont know whats going on but the lact of oil pressure scares me. I'll check oil level again when i get home. Any suggestions?
Old May 3, 2003 | 11:10 AM
MEAN LT1's Avatar
ttt
Old May 4, 2003 | 12:53 AM
engineermike's Avatar
When diagnosing oil pressure problems, it is important to verify guage readings with a second mechanical guage.
When I built a motor for my last car, it kept blowing oil filters off of the engine. The stock dash guage only showed 50 - 60 psi, though. Upon hooking up a mechanical guage, I found that the pressure was really going to 200+ psi (!). By the way, Loctite had found its way into the oil pump internal bypass valve and froze it shut, so there was no internal limit on oil pressure.
Mike
Old May 4, 2003 | 06:08 AM
MEAN LT1's Avatar
Mike
Wow...200psi!, I want oil pressure and all but geez
I will try that also and probably switch to a thicker oil like 10w30 and see how that will work.
Old May 4, 2003 | 12:06 PM
sleeperz28's Avatar
let me guess you were running 0W 30? if so I see your problem when the car warms up
Old May 4, 2003 | 02:29 PM
MEAN LT1's Avatar
No, Im running Mobile 1 5w30
Old May 5, 2003 | 10:58 AM
MEAN LT1's Avatar
Any other suggestions, Cold the loss of oil pressure be due to the fact that im also feeding the s/c with oil as well?, or could it be that that im losing viscosity as the car warms up?.
Old May 5, 2003 | 07:18 PM
If there is no internal problem in your blower, the oil flow to it should be very small, so it shouldn't affect your oil pressure.
With my T-trim, my oil pressure is around 20 psi at idle and 60 psi from 1500 rpm and up.
Mike
Old May 5, 2003 | 07:21 PM
Unless, of course, the addition of a supercharger caused detonation, which beat-up a main bearing, which causes oil pressure to drop.
Hope not, though. . .
Mike
Old May 6, 2003 | 10:40 AM
MEAN LT1's Avatar
Mike
No, Im pretty sure I havent spun a bearing or anything like that. It happend after about 20 minutes of driving and I noticed oil pressure going down. On the highway at about 70mph oil pressure is at lik 38psi right under the middle line. I havent got into boost yet so i dough the superchager caused it. I wonder if its the oil pump going out?
Old May 6, 2003 | 10:45 PM
MEAN LT1's Avatar
Well, I have changed my oil to 15w50 and that has raised my oil pressure back up to more comfortable levels. You guys just dont know how happy I am to have oil pressue again.
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
transam_388
Mar 15, 2015 11:53 AM
Jessie4tin
Jan 7, 2015 08:53 AM
Jul 4, 2005 05:00 PM
