Looking for a Turbo Carb kit or setup
Do any of you guys know if there is a company out there that makes a Turbo Kit for a Carbed engine?Any body in here have a turbo carb setup?Im thinking of fabbing up one Ive been wanting to try this for quite some time now.
Try this board - http://www.boards2go.com/boards/boar...ser=huntracers
Fast90 I have a few qusetions about your turbo setup.What does your Complete carb turbo setup consist of?Like the For Example,the turbo,wategate,tubular manifold,ic etc.Can you provide me with some pictures sir?
Its a rajay kit with all High quailty parts. This kit comes with 2 cast iron manoilds. The drivers side is the turbo manifold. A chromed stainless steel crossover pipe. This conects the drivers side and passer side manifolds togeter.
A good condtion, Rayjay E10 turbo (that is the HIghest flowing turbo rajay makes).
Stainsteel chromes down pipe. 3 inch
All chrome pipes from turbo- carb adapter.
Basicly its a spacer plate.
This is a basic kit and will hold boost around 8-10psi. I know that a wastegate is not needed unless you want to go higher psi.
Give me you email address and I will send you pic.
I've seen kit not half is good as as this one going for sale for 1000+ I just need some money. Being I am out of work
