Large (FMIC) ###
Old Jul 16, 2006 | 06:12 PM
Schurters LT1's Avatar
Large (FMIC) ###
I have the larger XS power FMIC on my 95 T/A...Today i was drive around....and it was about 40ish*c out side a very hot day....I looked at the Gen 7 And saw the my IAT # were 55-56ish....and did not move from there......
So at this point i am 10-15 * above Ambient temp .........
Just So people no, this is a T-Trim and i am spinning it hard .......max out the RPM on the Blower......
Just for fun i will be spraying ALKY as well .......
Old Jul 16, 2006 | 09:00 PM
97WS6Pilot's Avatar
Re: Large (FMIC) ###
Can you give us pics? I'd like to see the front end of your Trans Am with it all installed.
Old Jul 16, 2006 | 10:47 PM
I would post pix.....if you can tell me how to post them on here.....
Old Jul 17, 2006 | 11:54 AM
BADST95's Avatar
Thumbs up Re: Large (FMIC) ###
Just cut it already! I would like to do a similar design to the T/A bumper as I did to my Formula bumper... just send me your bumper.
Old Jul 17, 2006 | 12:06 PM
T/A KID's Avatar
I have an LS1 front clip on my car and I ordered this Bumper last week, I think with what I have plan it will look killer.
[IMG][/IMG]
BADST95 I heard you once say that your single plain bettered your LT1 intake by 70RWHP with your application. Reason be I have a LT4 intake opened for my Monoblade and the Runners were done by GTP. I am thinking about selling it and goin with a Unported Victor E intake with a Stock style Elbow since I can use my Monoblade. But I only plan to spin the motor to 6200 on my VRE 383 with Ported AFR heads, What do you think??
Old Jul 17, 2006 | 12:59 PM
BADST95's Avatar
[IMG][/IMG]
My engine made 80 rwhp more throughout the RPM range than a car that had a 396/AFR heads with an F1 (almost the same combo as mine... actually a "little better"). Comparing the two dyno graphs clearly showed the my car made more horsepower throughout the RPM range while both cars having identical peak power. I have seen that elbow that will allow the use of the
LT1 style throttle body and I think it will work nicely. That'll save you the expense of getting a Ford throttle body, buying new sensors, harness pig tails, and re-wiring the harness. In a mild application, you could use the stock PCM without much difficuly I would imagine. I used an Accel fuel injection manifold, had some porting done to it, removed the thermostat housing and welded it closed, and machined the intake to work with the heads. What's nice about the Accel intake manifold is that it has the fuel injector bosses already there and you can get it with the fuel rails. You can find it on www.mrgasket.com (p/n 74139). Go to the Accel fuel injection part of the web site. I didn't want to machine the heads even though it would have been easier to do so. If for some reason I wanted change my heads... it will be easier to sell them un-modified.
Old Jul 17, 2006 | 01:44 PM
97WS6Pilot's Avatar
Originally Posted by BADST95
Just cut it already! I would like to do a similar design to the T/A bumper as I did to my Formula bumper... just send me your bumper. .
Yeh, I think yours looks sharp. Could you give me the dimensions of your intercooler and where to buy one?
I can't get myself to bring out the knife yet. I really like the looks of the 97 WS6 TA front end. I want it to look professional so anyone walking by would not notice it was not stock. I think some of those louvres you see on so many stock cars would look nice. I'm pretty good with fiberglass so I may end up "Macgyvering" one up.
Old Jul 17, 2006 | 02:10 PM
97WS6Pilot's Avatar
1. Click the Post Reply button at the top or bottom of your thread.
2. When the reply box displays click on the Insert Picture icon in the toolbar at the top. It looks like a postcard. A box will pop up for your link.
3. Find your picture on the web and copy the address and paste it into the box. Click Ok.
4. Now post any text you wish to accompany it and hit Submit Reply.
Now you must keep your end of the bargain.
Old Jul 17, 2006 | 02:54 PM
CALL911's Avatar
I definatly reccomend the FMIC. I don't care for the look of the hacked up bumpers though. I ran an air dam duct under my bumper to direct air to the FMIC, and although I am sure it doesn't do as well as the posts above, it still keeps my air temps low.
Old Jul 17, 2006 | 03:33 PM
jrutland's Avatar
I believe these are Schurters pictures. I posted them in another thread as well.
Jerry
Old Jul 17, 2006 | 03:36 PM
jrutland's Avatar
Hey Schurters,
Where did you get all your pipeing for the intercooler? I am looking at doing pretty much the exact same as you.
Thanks,
Jerry
Old Jul 17, 2006 | 05:07 PM
Ok the pix are in my sig now......
Old Jul 17, 2006 | 05:09 PM
BADST95 can you give me the run down of all the parts the you have in to your intake set...i am looking into doing that this winter...and would like to now what i need..
thanks
Old Jul 18, 2006 | 07:34 AM
jrutland's Avatar
Originally Posted by jrutland
Hey Schurters,
Thanks,
Jerry
Any info?
Old Jul 18, 2006 | 07:49 AM
bowtiepwr's Avatar
Any info?
>I got mine off EBay just put " 3" intercooler pipe " in the search ( http://cgi.ebay.com/ebaymotors/3-Int...09337795QQrdZ1 )
or go to:
http://www.turbohoses.com/metal_piping.htm
or
http://www.sd-concepts.com/cart/inde...products_id=60
