Knock retard gurus, please step inside
Old Apr 24, 2003 | 09:56 AM
  #31
Tech's Avatar
Originally posted by Dan K
Jason,
I looked at the datamaster logs that you sent and e-mailed you back, but just thought I'd share what I found.
Your knock does not START at high rpm OR high map. 90% of the retard you see is in fuel trim cell 11, with rpm's at about 2800, map at about 65-70. Also throttle is between 1/4 and 1/3 (going by TPS %). Eventually you might get to a higher rpm or tps, but that is not where the knock starts.
Some of this is false knock and some of it is real.
If I were you I would track down the false knock and pull some timing out based on where the knock first starts in the logs and go from there.
Not sure what else to tell you, but I wish I could help more.
According to the logs which I sent (the most recent I have at work), that may be the case. While driving I can bury the throttle and everything is fine until I hit 3k RPMs and BOOM a large spike. I get peak KR around this area. I've pulled timing from 3000+ PRM and higher MAP values (can't remember the exact number) without any change.
How did you determine which knock is real and false? I assumed running race fuel would rule out false knock since I still got very similar KR.
I appreciate the help!
Old Apr 24, 2003 | 01:12 PM
  #32
Ernest's Avatar
The only thing I can add is to actually remove and reseat the knock sensor into the block, using as accurate a torque wrench as you can. I have seen a few cases where it was just a little too tight, and this caused it to be too "sensitive", setting off prematurely.
-Ernest
95 Z
Old Apr 24, 2003 | 01:27 PM
  #33
Tech's Avatar
Thanks Ernest. I have replaced my KS and was sure to torque to 14 ftlbs.
Old Apr 24, 2003 | 05:29 PM
  #34
Dan K's Avatar
You're saying "bury the throttle"....I don't see TPS get above 1.X volts ever. Nor does TPS% get much over 35ish. Have you checked that the TPS goes from the .65v closed at idle that you have to 4.25+ volts at wot? Does it go up linearly?
Again, the knock retard is coming in before 3000rpm...usually starts right at 2700rpm and about 60-70map.
Check the TPS though....
Old Apr 24, 2003 | 06:12 PM
  #35
Tech's Avatar
I'll check the TPS, thanks.
The reason why you didn't see 100% TPS is because the car had the blower on it and it hadn't been tuned. Like I mentioned, those were the only files I had at work. I'll gladly send you some updated ones tomorrow.
Old Apr 24, 2003 | 07:33 PM
  #36
Dan K's Avatar
Sure, send me whatever you want. I'll help as much as I can.
Formula Steve
Sep 19, 2023 08:31 AM
RubyRedIrocZ
3rd Gen / L98 Engine Tech
Sep 10, 2015 01:48 PM
z28newbie
Sep 9, 2015 10:26 AM
z28newbie
asilomar244
Jul 12, 2015 05:53 AM
