Intercooler set up
Old 07-04-2018, 12:26 PM
Gio93z's Avatar
Intercooler set up
Can I see some pics of YOUR LT1 Intercooler set ups for supercharged forced induction. Pics and product details are greatly appreciated. Thanks everyone!!
Gio93z is offline
Old 07-08-2018, 02:32 AM
Greg88's Avatar
Re: Intercooler set up
I originally had the twin intercooler set up for my Procharger D1SC. My tuner said it was junk, along with a lot of other people here online. So I bought a cheap eBay (CX Racing) intercooler and a universal set of 3” piping and made my own kit. I should have just done this from the beginning instead of messing with the twin intercooler Procharger set up. I want to say the front mount intercooler cost me $100 and the piping was $150 from China. I had to buy a few 3.5” elbows and couplers because I bumped the size up to 3.5 basically out of the exit side of the intercooler (drivers side).
Attached Thumbnails Intercooler set up-05a80f21-c0ff-42f1-b965-2019d7212903.jpeg   Intercooler set up-22944264-314f-4952-a90c-a73be520d266.jpeg   Intercooler set up-97170321-eb86-464b-b460-1acb536ba59b.jpeg
Greg88 is offline
Old 07-08-2018, 11:31 AM
Gio93z's Avatar
Thanks for the pics and info. Tell me about your blowoff valve. I’m currently running a bypass valve in my throttle body elbow which I’d like to keep.....
Gio93z is offline
Old 07-08-2018, 08:19 PM
Greg88's Avatar
This is considered a bypass valve as well apparently. You could definitely keep you current set up. I welded that pipe and flange onto my intercooling piping as well. You could weld a smaller pipe (same diameter as your bypass valve) run a hose to your bypass and then from bypass to your inlet. Aluminum is better for weight and displaces heat better. Just tougher to work with (welding)
Greg88 is offline
Old 07-08-2018, 09:09 PM
Gio93z's Avatar
Here’s what I was talking about. Thank you again
Gio93z is offline
Old 07-08-2018, 09:11 PM
Gio93z's Avatar
Gio93z is offline
Greg88's Avatar
Greg88 is offline
Old 07-21-2018, 02:42 PM
Greg88's Avatar
I don't see why you cant keep that Bypass Valve in that place. Although from what I have understood, its better to have it closer to the outlet side of the supercharger due to the fact that all your piping will now be charged because the valve is at the very end of all the piping, if that makes sense. better to have it closer to the outlet so there isn't a lag from the bypass valve to the blower.
Greg88 is offline
c0rey
12-06-2004 10:28 PM
IDOXLR8
06-04-2004 12:36 PM
bowtiepwr
05-07-2004 10:03 AM
1st and goal
09-09-2003 11:00 PM
1LEThumper
08-26-2003 03:26 PM
Quick Reply: Intercooler set up
