Injectors?
Old Jan 30, 2006 | 09:40 PM
cbrakllr88's Avatar
Injectors?
Whts up, I have an 01 Z with just long-tubes,converter,and flexplate. I ordered a D-1sc and Im going to run 8lbs. What type of #'s do you think I will make? Also what size injectors should I go with? Should I do a fuel pump or could I wait a little while?(Will be forging it in a little to run more lbs.)Thanks for the help.
Old Jan 30, 2006 | 10:30 PM
NYSS Guy's Avatar
Re: Injectors?
I have no idea on power #'s, but fuel is the second most important part of a FI build (right behind the tune). If you are going to go more boost later, get 60# injectors, and do the fuel pump. That should keep you okay up to the 600-650 rwhp range.
As a guess, maybe you'll be in the mid to upper 400's rwhp.
Old Jan 30, 2006 | 10:31 PM
NYSS Guy's Avatar
Re: Injectors?
Hmm, just noticed your in Jupiter, that's only about 20 minutes from my house!
Old Jan 31, 2006 | 12:44 PM
cbrakllr88's Avatar
NYSS guy
hey u said you were about 20mins. from jupiter. were are you located? Do you ever make around jupiter cause I might have seen your car.
Old Jan 31, 2006 | 01:15 PM
Roadie's Avatar
Re: NYSS guy
i have a set of flow-matched 57lb/hr siemens injectors for sale in the marketplace with _very_ little use... they're high-z injectors, so they work with the stock PCM.
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
