Ideal Piston reccomendations?
Old Apr 28, 2005 | 01:57 AM
Heatmaker's Avatar
Advanced Member
Interested in an 8-1 forged setup to handle big boost. What Piston do you guys reccomend and why?
Old Apr 28, 2005 | 03:41 AM
n2oblkz
Guest
Posts: n/a
Re: Ideal Piston reccomendations?
I am using the Diamond forged -22cc blower piston for my buildup. It is used out of the same aluminum as the top of the line JE blower pistons but at a more reasonable price. My pistons are rated at 20 pounds of boost but I have seen cars that are successfully running more with the same piston. I had another thread showing the differences in the metals of the JE and SRP pistons and the Diamonds. I'll see if I can find it for you. Diamond also makes some custom blower pistons if you are wanting to go more than 20 pounds of boost. JE, Diamond and CP are all really good pistons. It just depends on how much you are willing to spend.
Old Apr 28, 2005 | 03:46 AM
n2oblkz
Guest
Posts: n/a
Here is the link that I was talking about. Also, if you are wanting to run high boost, most builders will tell you to stay with a .10 or .20 over piston to keep the cylinder walls as thick as possible but you can go .30 and be OK.
LINK:
http://web.camaross.com/forums/showthread.php?t=345653
Old Apr 28, 2005 | 05:43 AM
97WS6SCharged's Avatar
I've got a set of JE 31cc dished pistons for my 383. Everyone else was using them so I figured they would probably work pretty well. Darn peer pressure.
Old Apr 28, 2005 | 09:29 AM
Heatmaker's Avatar
Advanced Member
Thanks U guys
I've been flipping through the summit catalog for the past week... like ??? What the hell...
I'm in the works of a Forged 383
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
95craz28
11
Sep 12, 2015 07:47 AM
gonzo275rltw
Sep 5, 2015 06:26 PM
gonzo275rltw
Sep 5, 2015 06:24 PM
