IC after S/C?
Old Jan 7, 2004 | 05:17 PM
mastrdrver's Avatar
IC after S/C?
I am planning on putting a KB S/C on a LS1 truck and was wondering about putting a IC on before, but was wondering if it would do any help at all?
Jeremy
Old Jan 7, 2004 | 05:22 PM
aram's Avatar
not really.. the way to do it is create a "plate" with a kind of radiator that the air passes through that water is run through and put that in between the intake manifold and the supercharger.
Old Jan 7, 2004 | 06:15 PM
mastrdrver's Avatar
Two questions:
1)Doesn't ATI mount their ICs before the S/C?
2)Do you think that I could get enough water from what would normally go through the tb to be effective?
Old Jan 7, 2004 | 06:30 PM
aram's Avatar
I'm guessing the one you are talking about mounts right on top of the motor and is not a centrifugal type blower.
... and
1. No, why would they do that? it doesn't make any sense.
2. You probably would be able to get enough flow but the water would be really hot which would not be ideal. The setup I made used it's own seperate water/pump and ice tank to keep the water as cold as possible.
Cbr02
Aug 23, 2015 10:55 PM
Z28x
23
Feb 3, 2004 05:29 PM
Teal94V-6
Jan 22, 2004 05:29 PM
ZeR0 Traction
Jan 8, 2004 03:12 PM
wannabeZo6
Dec 22, 2003 01:46 AM
